跳转到主内容
Lenovo Yoga 3 11 Lower Case Replacement
Geoff Wacker
Geoff Wacker
最后更新于 April 14, 2019
没有估计
中等
需要更多图片
Use this guide to replace the lower case in your Lenovo Yoga 3 11.
你所需要的
工具
  1. Lenovo Yoga 3 11 Lower Case Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
结论
2等其他人完成本指南。
Geoff Wacker
于09/30/13注册
91,085 声望
创作了89篇指南
一条评论
Once you remove the T5 screws take notice of the two places where the lower cases design accounts for the LCD hinges. The lower case wraps over the edge and extends the entire length of the machine on the LCD edge to meet the black plastic of the upper case. You may want to use a thin edged sponger at points on either side of each hinge to dislodge the lower case. I found it best to begin removal of the lower case from the LCD edge. Once that edge is released the rest of the lower case will be much easier to release and remove. Subsequently when installing the new case begin by placing the LCD edge first. Go in at an angle necessary to set the edge that wraps over. This guide and this comment applies to the 3 11 and the 3 14.
John Wolmer - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 1,698
