跳转到主内容
Lenovo Thinkpad Yoga 370  M2 SSD Replacement
Ramiro
Ramiro2 其他贡献者
最后更新于 November 15, 2022
7分钟
简单
社区贡献指南
Here it is explained step by step how to replace a M2 SSD of the Lenovo Thinkpad Yoga 370. The specific model code can be found in the sticker with the serial number. In my case it is 20JJ. The materials I have used are:
  • New M2 SSD compatible with your model
  • Screw like Phillips #1 Screwdriver or the tool provided on iFixit Tool.
I recommend to download also from Lenovo the official guides of your laptop as they have diagrams with the description of the motherboards and its components. In my case:
https://download.lenovo.com/pccbbs/mobil...
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Identify the specific model and locate the screws to loose: 步骤 1 中的图像 1,2 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Identify the specific model and locate the screws to loose: 步骤 1 中的图像 2,2
    • Before remove the back-case of the laptop we have to remove the Pen Pro and the SD card if it is in your model (two boxes in orange on one of the photos).
    • Circles show the screws to loose. The yellow square indicates where the information about Model is found (20JJ in this case).
  2. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Loose the screws and take away the back case: 步骤 2 中的图像 1,3 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Loose the screws and take away the back case: 步骤 2 中的图像 2,3 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Loose the screws and take away the back case: 步骤 2 中的图像 3,3
    • Note that after loose the screws we have to remove the case from the bottom part.
    • The all the screws remain attached to the back-cover as shown in the photos.
    • Note that the top part of the laptop back cover has several hooks done with plastic (see the photos with blue squares)
  3. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Identify the M2.SSD and the screw that attach it to the main board: 步骤 3 中的图像 1,2 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Identify the M2.SSD and the screw that attach it to the main board: 步骤 3 中的图像 2,2
    • Laptop after remove the back-cover. The area in red has the M2.SSD.
    • The blue arrow shows where is the adhesive part of the M2.SSD that we have to carefully lift off but keeping attached the other part of the cover.
    • The green arrow shows the screw that we would have to remove to take away the M2.SSD.
  4. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Remove the screw and insert the M2.SSD.: 步骤 4 中的图像 1,3 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Remove the screw and insert the M2.SSD.: 步骤 4 中的图像 2,3 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Remove the screw and insert the M2.SSD.: 步骤 4 中的图像 3,3
    • First step is remove the screw (this one has to be full removed).
    • Then we can introduce the new M2.SSD, with a little bit of pressure.
    • Finally we can fix it with the previously removed screw. Everything should fit well without forcing any component.
  5. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Attach again the back case.: 步骤 5 中的图像 1,1
    • To close the back case of the laptop we have to remember the position of the small hooks. Then apply some pressure and screw first the screws on top
    • After screw again all the 9 screws, we can attach again the Pen Pro and the SD card.
    • Its done.
结论
2等其他人完成本指南。
附加文件
Ramiro
于03/08/19注册
178 声望
撰写一个指南
一条评论
excellent and easy to follow instruction. I used your set and sent it to a senior that needed to fix their laptops. No prior experience. It worked like a charm.
Austin - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 23
过去 30 天: 54
总计 6,654
