跳转到主内容
Lenovo ThinkPad Yoga 370 Screen Replacement
Chenoa Begaye
Chenoa Begaye6 其他贡献者
最后更新于 May 7, 2024
20 - 40 分钟
中等
更好的介绍
The screen is a crucial part of a laptop. A screen that is damaged and broken can cause many problems in the display of information. Follow this guide to learn how to replace the screen on a Lenovo Thinkpad Yoga 370.
Before beginning this repair, power off your device and unplug from your power adapter.
你所需要的
配件
工具
查看更多...
  1. Lenovo ThinkPad Yoga 370 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Remove rubber plugs on the lower corners of the screen
    • Unscrew screws under the rubber plugs
  2. Lenovo ThinkPad Yoga 370 Screen Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Yoga 370 Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the four 4 mm screws along the bottom of the display.
  3. Lenovo ThinkPad Yoga 370 Screen Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Using tweezers, remove the tape from the display cable below the screen.
  4. Lenovo ThinkPad Yoga 370 Screen Replacement: 步骤 4 中的图像 1,1
    • Slide the screen downwards towards the keyboard.
    • Lift the screen slowly from the frame when the screen is slid down completely.
    • The screen is still attached to the computer, do not pull away from the laptop frame until a later step.
    • Flip the screen over and lay face down on the keyboard.
  5. Lenovo ThinkPad Yoga 370 Screen Replacement: 步骤 5 中的图像 1,3 Lenovo ThinkPad Yoga 370 Screen Replacement: 步骤 5 中的图像 2,3 Lenovo ThinkPad Yoga 370 Screen Replacement: 步骤 5 中的图像 3,3
    • Peel the tape off from the back of the screen, connecting the display to the device.
    • Remove the screen.
结论
另外一个人完成了本指南。
1指南评论
I strongly recommend to at least unplug the battery before replacing the screen. I fried a motherboard once by manipulating a screen ribbon while the battery was still plugged in.
You should always unplug the battery before working on a device anyway.
lululock - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 62
总计 2,858
