跳转到主内容
Lenovo ThinkPad Yoga 260 Trackpad Replacement
Tovo
Tovo2 其他贡献者
最后更新于 July 1, 2020
10 - 15 分钟
中等
If the trackpad for your Lenovo Thinkpad Yoga 260 (Model Number: 20FD002HUS) is defective or broken, this guide will carefully walk you through the steps to replace it.
If your trackpad  is not as responsive as it once was, the mouse not synced with your movements, or the trackpad not operating as normal you may consider replacing the trackpad.
Before using this guide ensure the laptop is powered off, disconnected from external power sources, and you have the listed tools available for use.
你所需要的
工具
  1. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 3 中的图像 2,2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 4 中的图像 2,2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: 步骤 5 中的图像 1,3 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: 步骤 5 中的图像 2,3 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Battery: 步骤 5 中的图像 3,3
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 6 中的图像 3,3
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
  7. Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: 步骤 7 中的图像 1,3 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: 步骤 7 中的图像 2,3 Lenovo ThinkPad Yoga 260 Trackpad Replacement, Trackpad: 步骤 7 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove the four 1.3mm Philips #1 fasteners from the back of the trackpad and set them aside.
  8. Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 8 中的图像 1,2 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 8 中的图像 2,2
    • Using your index finger and thumb gently pull the blue tab located at the top of the trackpad back from the assembly.
  9. Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 9 中的图像 1,3 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 9 中的图像 2,3 Lenovo ThinkPad Yoga 260 Trackpad Replacement: 步骤 9 中的图像 3,3
    • Flip the device right side up.
    • Open the computer.
    • Gently lift the trackpad out of the computer assembly.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 1,390
