跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad Yoga 260 Repair RAM Replacement
Daniel Fernandez
Daniel Fernandez3 其他贡献者
最后更新于 2024年3月20日
5 - 10 分钟
简单
RAM or Random Access Memory, is a type of memory that temporarily stores information. If you have a faulty RAM or you are upgrading it, this guide will help you replace it.
你所需要的
配件
工具
查看更多...
  1. Lenovo ThinkPad Yoga 260 Repair RAM Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair RAM Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Yoga 260 Repair RAM Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair RAM Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad Yoga 260 Repair RAM Replacement: 步骤 3 中的图像 2,2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair RAM Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad Yoga 260 Repair RAM Replacement: 步骤 4 中的图像 2,2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair RAM Replacement, RAM: 步骤 5 中的图像 1,2 Lenovo ThinkPad Yoga 260 Repair RAM Replacement, RAM: 步骤 5 中的图像 2,2
    • Using both thumbs, pinch the RAM's mounting clips outward.
    • The RAM module will spring up on its own.
  6. Lenovo ThinkPad Yoga 260 Repair RAM Replacement: 步骤 6 中的图像 1,1
    • Gently remove it from its mounting.
结论
4等其他人完成本指南。
为未来的维修做好准备
全部购物
团队
USF Tampa, Team S2-G3, Eyestone Spring 2018 USF Tampa, Team S2-G3, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S2G3
4 名成员
创作了9篇指南
3指南评论
how many ram slot in lenovo yoga 260
The Great - 回复
Just 1 slot :-(
Erik Chorn -
Hello,
I need help.
My yoga 260 does not have any slot and I already bought a 16gb ddr4
tovitottovi963 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 32
总计 3,437
