跳转到主内容
Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement
Daniel Fernandez
Daniel Fernandez4 其他贡献者
最后更新于 January 22, 2020
10 - 15 分钟
中等
The hard drive is a storage device that permanently stores information. If you have a faulty hard drive or you are upgrading it, this guide will help you replace it.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 步骤 3 中的图像 2,2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,3 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,3 Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 3,3
    • Pull back the plastic heat shield over the hard drive without tearing or completely removing it.
  6. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Using a Phillips screwdriver, remove the PH1 Phillips fastener and set it aside.
  7. Lenovo ThinkPad Yoga 260 Repair Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Using your index finger and thumb, gently pull the hard drive from its connection and remove it from the laptop.
结论
8等其他人完成本指南。
团队
USF Tampa, Team S2-G3, Eyestone Spring 2018 USF Tampa, Team S2-G3, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S2G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 16
过去 30 天: 32
总计 6,791
