跳转到主内容
Lenovo ThinkPad Yoga 260 Repair Battery Replacement
你所需要的
  1. Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 步骤 3 中的图像 2,2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 步骤 4 中的图像 2,2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Battery: 步骤 5 中的图像 1,3 Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Battery: 步骤 5 中的图像 2,3 Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Battery: 步骤 5 中的图像 3,3
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: 步骤 6 中的图像 3,3
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
结论
7等其他人完成本指南。
团队
USF Tampa, Team S2-G3, Eyestone Spring 2018 USF Tampa, Team S2-G3, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S2G3
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 14
过去 30 天: 32
总计 7,654
