跳转到主内容
Lenovo ThinkPad Yoga 260 Motherboard Replacement
Ian Jenkins
Ian Jenkins3 其他贡献者
最后更新于 July 1, 2020
30 - 40 分钟
困难
If the motherboard for your Lenovo Thinkpad Yoga 260 (Model Number: 20FD002HUS) is defective or broken, this guide will carefully walk you through the steps to replace it.
If your computer is often failing to boot or you are experiencing random freezing issues and “blue screens of death” you may consider replacing the motherboard.
Before using this guide ensure the laptop is powered off, disconnected from external power sources, and you have the listed tools available for use.
你所需要的
工具
查看更多...
  1. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 3 中的图像 2,2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 4 中的图像 1,2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Battery: 步骤 5 中的图像 1,3 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Battery: 步骤 5 中的图像 2,3 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Battery: 步骤 5 中的图像 3,3
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 6 中的图像 1,3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 6 中的图像 2,3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
  7. Lenovo ThinkPad Yoga 260 Motherboard Replacement, RAM: 步骤 7 中的图像 1,2 Lenovo ThinkPad Yoga 260 Motherboard Replacement, RAM: 步骤 7 中的图像 2,2
    • Using both thumbs, pinch the RAM's mounting clips outward.
    • The RAM module will spring up on its own.
  8. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Gently remove it from its mounting.
  9. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Heat Sink: 步骤 9 中的图像 1,2 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Heat Sink: 步骤 9 中的图像 2,2
    • Heatsink should be cool to the touch.
    • Using your index fingers, gently remove the fan’s power connection.
  10. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 10 中的图像 1,2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the four 1.3 mm Phillips #1 screws and set them aside.
    • The screws will not separate from the mounting when loose.
  11. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Using your index finger and thumb, gently pry the cooler from its mountings and remove the assembly.
  12. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Wifi-Card: 步骤 12 中的图像 1,3 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Wifi-Card: 步骤 12 中的图像 2,3 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Wifi-Card: 步骤 12 中的图像 3,3
    • Using a Phillips #1 screwdriver, remove the 1.3 mm screw and set it aside.
  13. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 13 中的图像 1,2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Carefully pull out the Wi-Fi card.
    • Be sure to pull laterally, not upwards.
  14. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 14 中的图像 1,2 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Carefully disconnect the 2 cables from the WiFi-Card as indicated on the card label.
    • Set the Wifi-Card aside.
  15. Lenovo ThinkPad Yoga 260 Motherboard Replacement, Motherboard: 步骤 15 中的图像 1,2 Lenovo ThinkPad Yoga 260 Motherboard Replacement, Motherboard: 步骤 15 中的图像 2,2
    • Disconnect the speaker cable located near hinge side of the laptop.
    • Remove both speakers from the assembly.
  16. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 16 中的图像 1,3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 16 中的图像 2,3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 16 中的图像 3,3
    • Gently lift up the SD chip's black protective film.
    • Unplug the SD chip from the assembly and set the SD chip aside.
  17. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 17 中的图像 1,3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 17 中的图像 2,3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 17 中的图像 3,3
    • Pull up on the 2 black tabs to remove the cords located along the hinge edge of the device.
  18. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 18 中的图像 1,3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 18 中的图像 2,3 Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 18 中的图像 3,3
    • Pull up the 6 colored tabs along the edge of the motherboard to disconnect them from the motherboard.
  19. Lenovo ThinkPad Yoga 260 Motherboard Replacement: 步骤 19 中的图像 1,1
    • Remove the fourteen .8 mm screws on the motherboard using a Phillips #00 screwdriver.
    • Carefully lift the motherboard out of assembly.
    • Ensure no wires or cables remain connected.
结论
6等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 27
总计 2,503
