跳转到主内容
Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement
Ashley Haraguchi
Ashley Haraguchi6 其他贡献者
最后更新于 August 1, 2023
5分钟
简单
If you are running out of storage space on your laptop, you can either transfer files to an external storage device or follow this guide to replace and upgrade your solid-state drive. Before you do so, check how much storage space you have on your laptop, which will help you decide if you need to upgrade the SSD or not. The Lenovo X1 ThinkPad Yoga 2nd Generation comes with a 256 GB SSD, so you have the option to upgrade to a 512 GB or 1 TB SSD.
Additionally, back up your SSD before you replace it so you do not lose any data. These instructions can also be followed to simply transfer files to an external storage device.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement, SSD: 步骤 4 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation SSD Replacement: 步骤 5 中的图像 2,2
    • Slide the SSD out of the shiny covering.
    • Remove the SSD.
结论
9等其他人完成本指南。
团队
Cal Poly, Team S22-G3, Regan Winter 2020 Cal Poly, Team S22-G3, Regan Winter 2020 的会员
CPSU-REGAN-W20S22G3
5 名成员
创作了7篇指南
一条评论
What kind of SSD is this compatible with? There are several different connector standards…
Shai Revzen - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 97
总计 8,120
