跳转到主内容
Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement
Madeline Elizabeth Schmuck
Madeline Elizabeth Schmuck5 其他贡献者
最后更新于 April 17, 2024
30 - 45 分钟
中等
需要更好的图片
If your Lenovo ThinkPad X1 Yoga 2nd Generation won’t turn on use this guide to replace the motherboard.
First check that it is not a faulty battery by checking or replacing the battery first as this could be the reason the Lenovo ThinkPad won’t turn on. Before replacing the battery, ensure your power adaptor is not the issue as well. To check if your adaptor is the problem, borrow and test a different adaptor. If the laptop charges during the test, you need to replace your power adaptor.
Before beginning, make sure to power off your phone completely and disconnect from any external power source.
你所需要的
配件
工具
查看更多...
  1. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Ensure the laptop is powered off and the charging cable is disconnected before opening the back cover.
    • Flip over the laptop to access the back cover.
  2. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the eight 8 mm screws.
  3. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 3 中的图像 1,1
    • Remove the back cover.
    • A popping sound may occur when the back cover is removed.
  4. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Speakers: 步骤 4 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Speakers: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    $3.99
    • Follow the ribbon cable that runs from the left speaker to the motherboard.
    • Pull the black connector up and release the cable wire by hand.
    • If needed, pull this connector up using the Pro/ESD/angled tweezers.
  5. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 5 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 5 中的图像 2,2
    • Remove two 6 mm Phillips #0 screws from each speaker.
  6. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 6 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 6 中的图像 2,2
    • Use your fingers to remove the speakers from the device.
  7. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Battery: 步骤 7 中的图像 1,1
    • Use a spudger to pop the ribbon cable that runs from the upper-middle portion of the battery to the motherboard out of the motherboard.
    • Do not use a metal spudger as indicated in the photos. The metal spudger should only be used for serious prying power. If it's used on the internal components of a device, it may puncture or damage the components in your device.
  8. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 8 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove one 6 mm screw from the bottom-middle portion of the battery.
  9. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 9 中的图像 1,1
    • Remove the battery.
  10. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Fan: 步骤 10 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Fan: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    • Lift up the small, metal tab using a spudger.
    • Do not use the metal spudger unless if it's being used for serious prying power. The metal spudger may damage or puncture internal components in the device if too much pressure is applied.
    • Gently lift the ribbon cable from its socket using nylon-tipped reverse tweezers.
  11. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 11 中的图像 1,1
    • Using the Phillips #0 screwdriver, unscrew the four 4 mm screws directly next to the fan.
  12. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 12 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 12 中的图像 2,2
    • Loosen the four 5 mm screws in the metal extension attached to the fan.
    • The screws do not need to be completely removed from the fan.
    • Remove the fan using your fingers.
  13. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement, Mother Board: 步骤 13 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove all 16 of the 6 mm screws connecting the motherboard to the computer.
  14. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 14 中的图像 1,2 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 14 中的图像 2,2
    • Using the nylon spudger, disconnect the grey and black wires.
    • Using the nylon spudger, gently disconnect the pink tab from the motherboard.
  15. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 15 中的图像 1,1
    • Carefully remove the black tape with your fingers.
    • Do not remove the sticky residue from the back of the section.
  16. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 16 中的图像 1,3 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 16 中的图像 2,3 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 16 中的图像 3,3
    • Lift the Black flap using a plastic spudger.
    • Pull out the ribbon cable with the black tab.
  17. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 17 中的图像 1,1
    • Remove the purple tab by gently pulling it out.
  18. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 18 中的图像 1,1
    • Remove the blue tab by gently pulling it out.
  19. Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 19 中的图像 1,3 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 19 中的图像 2,3 Lenovo ThinkPad X1 Yoga 2nd Generation Mother Board Replacement: 步骤 19 中的图像 3,3
    • Gently lift up on the sides with your hands and remove the motherboard.
结论
另外一个人完成了本指南。
1指南评论
So searching for motherboards, there are several different "gens". Can any of these be used to replace one? Or is it necessary to replace with the same gen?
Bryant Hayward - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 35
总计 1,898
