跳转到主内容
Lenovo ThinkPad X1 Extreme SSD Replacement
Addy Botao Liu
Addy Botao Liu5 其他贡献者
最后更新于 January 17, 2025
15 - 25 分钟
简单
需要更好的图片
This guide will lead you through the steps to replace the SSD card on the Lenovo ThinkPad X1 Extreme Generation 1. The SSD card, or solid-state drive, acts as extra storage for the device, however, oftentimes the SSD can wear out, or run slower with age.
The steps to replace the SSD card are simple, the hardest part being keeping track of all the screws while taking apart the device.
It is important to remember to turn off the device while replacing the SSD card.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: 步骤 1 中的图像 1,3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: 步骤 1 中的图像 2,3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Power off and unplug your device before you begin.
    • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
    • Unscrew the seven captive screws with a Phillips #00 screwdriver.
    • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
    • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
    • Remove the back cover from the device.
  2. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: 步骤 2 中的图像 2,2
    • Using the Phillips #00 screwdriver, remove the single screw securing the SSD to the motherboard.
  3. Lenovo ThinkPad X1 Extreme SSD Replacement: 步骤 3 中的图像 1,2 Lenovo ThinkPad X1 Extreme SSD Replacement: 步骤 3 中的图像 2,2
    • Using the opening tool, pop out the SSD card and remove it from the device.
结论
另外一个人完成了本指南。
1指南评论
Anyhow this laptop support gen 4 nvme or higher?
jordan chong - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 48
总计 2,351
