Lenovo ThinkPad X1 Extreme SSD Replacement
简介
转到步骤 1This guide will lead you through the steps to replace the SSD card on the Lenovo ThinkPad X1 Extreme Generation 1. The SSD card, or solid-state drive, acts as extra storage for the device, however, oftentimes the SSD can wear out, or run slower with age.
The steps to replace the SSD card are simple, the hardest part being keeping track of all the screws while taking apart the device.
It is important to remember to turn off the device while replacing the SSD card.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
Orient the laptop so that it is bottom up, and the trackpad is closest to you.
Unscrew the seven captive screws with a Phillips #00 screwdriver.
Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
Remove the back cover from the device.
另外一个人完成了本指南。
