跳转到主内容
Lenovo ThinkPad X1 Carbon 6th Gen Back Cover Replacement
Michael Megna
Michael Megna6 其他贡献者
最后更新于 March 17, 2022
4分钟
简单
This guide gives instructions to remove the back cover of the Lenovo ThinkPad X1 Carbon 6th Gen. This may be necessary if the cover is broken and needs to be replaced or if any internal components need to be accessed.
Before beginning, make sure the laptop is powered down, and the battery is below 25% charge.
你所需要的
工具
  1. Lenovo ThinkPad X1 Carbon 6th Gen Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use a Phillips #0 screwdriver to unscrew the five screws that secure the back cover to the laptop.
    • The screws do not completely come off from the back cover. Loosen until the screws are completely loose.
  2. Lenovo ThinkPad X1 Carbon 6th Gen Back Cover Replacement: 步骤 2 中的图像 1,2 Lenovo ThinkPad X1 Carbon 6th Gen Back Cover Replacement: 步骤 2 中的图像 2,2
    • Use a Jimmy to lift the cover directly up off of the locating pins.
    • Though a metal opening tool is shown in the image, we recommend using plastic opening tools to minimize any cosmetic damage.
    • Remove the back cover.
    • If you encounter resistance when lifting the cover, revisit the screws to see if any of them are still threaded on to the device.
结论
3等其他人完成本指南。
Michael Megna
于01/23/20注册
1,361 声望
创作了7篇指南
团队
Cal Poly, Team S19-G4, White Winter 2020 Cal Poly, Team S19-G4, White Winter 2020 的会员
CPSU-WHITE-W20S19G4
3 名成员
创作了23篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 90
总计 2,883
