简介
If your Lenovo Legion Y530-15ICH isn’t powering on or holding a charge then you should use this guide to replace the battery.
The battery provides power to the rest of the computer. If your computer won’t power on, you may have a faulty power cord or just need to restart your computer. Your problem may be due to a faulty battery or your battery may also be swollen.
Please make sure the laptop is powered off completely and unplugged before beginning.
你所需要的
Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
Five 7 mm screws
Six 4 mm screws
Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
For optimal performance, after completing this guide, calibrate your newly installed battery.
8等其他人完成本指南。
2条评论
Hello! I have a Lenovo Y530 laptop and its battery is swollen. After removing the battery and waiting for the replacement, can I directly plug in the laptop to the power without having the battery?
Hi Joshua,
Yes! Be careful to reassemble everything other than the laptop. The laptop should boot, though depending on the brand and model, some will refuse without a battery.
