跳转到主内容
Lenovo IdeaPad U450 Keyboard Replacement
Rachel L Rodrigues
Rachel L Rodrigues2 其他贡献者
最后更新于 May 19, 2017
5分钟
中等
动态照片拍摄
需要更多图片
The keyboard is an essential part of your computer and this guide will take you through the steps to replace your damaged one.
你所需要的
工具
查看更多...
  1. Lenovo IdeaPad U450 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Keyboard Replacement: 步骤 2 中的图像 1,1
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,1
    • Flip the laptop so it's facing upwards.
  6. Lenovo IdeaPad U450 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Open the laptop.
  7. Lenovo IdeaPad U450 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Press the most northern region above F6 and F7 until a bit of your keyboard pops out.
  8. Lenovo IdeaPad U450 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Use the spudger to pry the top of the keyboard out.
  9. Lenovo IdeaPad U450 Keyboard Replacement: 步骤 9 中的图像 1,1
    • Disconnect the wire connecting to keyboard to the laptop.
  10. Lenovo IdeaPad U450 Keyboard Replacement: 步骤 10 中的图像 1,1
    • Remove the keyboard
结论
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 19
总计 315
