跳转到主内容
Lenovo IdeaPad U430 Touch Motherboard Replacement
Babar  Ali
Babar Ali4 其他贡献者
最后更新于 May 7, 2024
30分钟 - 1小时
中等
Use this guide to replace a bad motherboard on your Lenovo Ideapad U430 touch.
你所需要的
工具
查看更多...
  1. Lenovo IdeaPad U430 Touch Motherboard Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 3 中的图像 2,2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Motherboard Replacement, Battery: 步骤 4 中的图像 1,2 Lenovo IdeaPad U430 Touch Motherboard Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the five 2.8 mm #1 Phillips head screws that hold down the battery pack.
  4. Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 5 中的图像 1,2 Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Using a combination of plastic opening tool and spudger, press in on the clips on the sides of the battery connector and push the connector out
    • When you get the connector out far enough, grab behind the connector tabs with tweezers and wiggle the connector the rest of the way out.
    • The battery connector is very tight fitting, you may need to use a metal spudger in order to get the connector out far enough.
  5. Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 6 中的图像 2,2
    • Once the battery is disconnected, lift up on the front of the battery and remove it from the laptop body.
  6. Lenovo IdeaPad U430 Touch Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,2 Lenovo IdeaPad U430 Touch Motherboard Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Disconnect all 5 ZIF ribbon connectors from the motherboard.
    • To disconnect a ZIF connector, use your fingernail or a plastic spudger to flip the retainer up, and gently pull the ribbon cable out.
  7. Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 8 中的图像 1,3 Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 8 中的图像 2,3 Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    • Using a plastic spudger, liift up and remove the hard drive and screen flat-topped connectors
    • Use the spudger and metal tweezers to remove the two cable connectors and two bundled cable connectors.
    • Use the plastic spudger to lift up and remove the two antenna connectors.
  8. Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 9 中的图像 1,3 Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 9 中的图像 2,3 Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 9 中的图像 3,3
    • Unscrew the three 3mm #1 Phillips head screws holding down the cooling assembly and fan.
    • These screws remain secured with the assembly.
    • Remove the cooling assembly from the motherboard.
  9. Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 10 中的图像 1,1
    • Unscrew all seven 2.8mm #1 Phillips head screws that secure the motherboard to the laptop.
  10. Lenovo IdeaPad U430 Touch Motherboard Replacement: 步骤 11 中的图像 1,1
    • Lift the motherboard out of the laptop case.
结论
3等其他人完成本指南。
Babar Ali
于02/28/17注册
152 声望
撰写一个指南
团队
USF Tampa, Team S2-G6, Nance Spring 2017 USF Tampa, Team S2-G6, Nance Spring 2017 的会员
USFT-NANCE-S17S2G6
3 名成员
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 33
总计 2,624
