跳转到主内容
Lenovo IdeaPad U430 Touch Hard Drive Replacement
Chris Dennis
Chris Dennis3 其他贡献者
最后更新于 November 18, 2022
5分钟
中等
需要更多图片
更好的介绍
This guide will take you through the steps to replace a broken or missing hard drive in the Lenovo IdeaPad U430 Touch
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Lenovo IdeaPad U430 Touch Hard Drive Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Hard Drive Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad U430 Touch Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Unplug the hard drive from the 22-pin cable (LZ9 HDD cable).
    • At the time of guide creation, the device did not come equipped with the hard drive.
  4. Lenovo IdeaPad U430 Touch Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Using the plastic opening tool, lift the hard drive from its compartment.
结论
另外一个人完成了本指南。
一条评论
1. Of the first 10 screws, you did not mention that 2 of them are longer.
2. You can't lift the hard drive out without removing 4 screws (one at each corner of the drive). The plastic tool is not needed for this.
Todd McQueen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 1,746
