跳转到主内容
Lenovo IdeaPad 300-17ISK Hard Drive Replacement
你所需要的
  1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Bottom Back Cover: 步骤 1 中的图像 1,1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • The hard drive is located at the bottom of the laptop.
  4. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Unscrew the four 6mm Phillips #1 screws that hold the hard drive frame in place.
  5. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Gently pick up the hard drive without pulling it completely out.
    • You shouldn't use excessive force because the hard drive is still attached to the motherboard.
  6. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 6 中的图像 1,2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Use the spudger to disconnect the hard drive from it motherboard connector.
    • The connector should come right off without excessive force.
  7. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 7 中的图像 1,2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Remove the four 3mm Phillips #1 screws, two on each side, that secure the hard drive in its protective frame.
    • These screws are different from the rest of the laptop screws. You can damage the drive using the wrong screws.
    • Lift the frame to separate it from the hard drive.
结论
10等其他人完成本指南。
Ammar Dodin
于01/19/17注册
1,057 声望
创作了6篇指南
团队
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 的会员
UCD-RODGER-W17S1G3
4 名成员
创作了6篇指南
3指南评论
Clear and easy - thanks!
Beth Pierce - 回复
Very good and to the point
al_stewart - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 12
过去 30 天: 40
总计 10,100
