跳转到主内容
Lenovo IdeaPad 3-15IGL05 SSD Replacement
Matthew Frederic
Matthew Frederic2 其他贡献者
最后更新于 November 15, 2022
15 - 25 分钟
中等
更好的介绍
This guide demonstrates how to replace a faulty, damaged, or corrupt SSD in your Lenovo IdeaPad 3-15IGL05.
Hard drives are commonly a point of failure in electronic devices, and replacing one is a relatively simple procedure if done properly.
This replacement will take about 20 minutes, but it can be completed much faster than that if you know what you’re doing.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Lenovo IdeaPad 3-15IGL05 SSD Replacement, SSD: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the ten 7.6 mm screws securing the bottom panel.
  2. Lenovo IdeaPad 3-15IGL05 SSD Replacement: 步骤 2 中的图像 1,2 Lenovo IdeaPad 3-15IGL05 SSD Replacement: 步骤 2 中的图像 2,2
    • Wedge an opening tool in the gap between the bottom panel and chassis, and pry vertically around the perimeter until you hear a "pop" and the panel releases.
    • Lift the bottom panel up and off the chassis.
  3. Lenovo IdeaPad 3-15IGL05 SSD Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad 3-15IGL05 SSD Replacement: 步骤 3 中的图像 2,2
    • Locate the SSD at the bottom right corner of the fan.
    • Use a Phillips #000 screwdriver to remove the single 3 mm screw securing the SSD.
    • The drive should slightly lift once the screw is removed.
  4. Lenovo IdeaPad 3-15IGL05 SSD Replacement: 步骤 4 中的图像 1,1
    • Gently pull the SSD directly out of its port.
    • Do not over-tighten the screws during reassembly.
结论
Matthew Frederic
于09/30/21注册
109 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 29
过去 30 天: 85
总计 3,484
