Lenovo IdeaPad 110-15IBR Hard Drive Replacement
简介
转到步骤 1If your computer won't boot and is having hard disk/hard drive reading errors, follow this guide to replace it. The guide shows how to remove the back from the device, unscrew the battery from the device, remove the drive from the dock, and unscrew the drive housing.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
Place laptop with the bottom facing up. Using a Philip #1 screwdriver unscrew all 13 screws. Gently pry the back out using a plastic opening tool, starting from one of the corners.
To reassemble your device, follow these instructions in reverse order with your new replacement hard drive.
14等其他人完成本指南。
3指南评论
Unplug or remove battery first?
Hard disk size?
you do not need to unplug or remove the battery
There are 3 more screws after removing dvd/cd drive
Mazwi Mbuso - 回复
