跳转到主内容
Lenovo IdeaPad 110-15IBR Hard Drive Replacement
Saddam  Alsinai
Saddam Alsinai9 其他贡献者
最后更新于 March 22, 2022
10分钟
简单
If your computer won't boot and is having hard disk/hard drive reading errors, follow this guide to replace it. The guide shows how to remove the back from the device, unscrew the battery from the device, remove the drive from the dock, and unscrew the drive housing.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: 步骤 1 中的图像 1,2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement, keyboard: 步骤 1 中的图像 2,2
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source. Before removing the drive, make a backup copy of all the information on it if possible. Never remove the drive while the system is operating or in suspend mode.
    • Place laptop with the bottom facing up. Using a Philip #1 screwdriver unscrew all 13 screws. Gently pry the back out using a plastic opening tool, starting from one of the corners.
    There are 3 more screws after removing dvd/cd drive
    Mazwi Mbuso - 回复
  2. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the four (5mm) screws holding the hard drive in place.
  3. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 步骤 3 中的图像 1,2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Do not lift hard drive straight up otherwise you might risk breaking the connection port.
    • Gently slide the hard drive away and out out of the connection port.
  4. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 步骤 4 中的图像 1,2 Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Using a Philip #1 screwdriver remove 2 screws from each side, (removing 4 screws in total) holding the hard drive into the housing.
  5. Lenovo IdeaPad 110-15IBR Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Remove hard drive from housing.
结论
To reassemble your device, follow these instructions in reverse order with your new replacement hard drive.
14等其他人完成本指南。
Saddam Alsinai
于10/18/17注册
687 声望
创作了4篇指南
团队
UW Tacoma, Team S3-G4, Liner Fall 2017 UW Tacoma, Team S3-G4, Liner Fall 2017 的会员
UWT-LINER-F17S3G4
4 名成员
创作了14篇指南
3指南评论
Unplug or remove battery first?
Chris Quirke - 回复
you do not need to unplug or remove the battery
Holden Phillips - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 20,254
