跳转到主内容
Lenovo Edge 15 Wireless LAN Card Replacement
ryan sanders
ryan sanders3 其他贡献者
最后更新于 January 3, 2018
10分钟
简单
This guide will give you step by step instructions on how to replace the Wireless LAN card in your Lenovo Edge 15.
你所需要的
配件
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Lenovo Edge 15 Wireless LAN Card Replacement, Wireless LAN Card: 步骤 1 中的图像 1,1
    • With the laptop upside-down, remove all 11 M2 x 6.0mm screws from the cover plate using the Phillips #0 screwdriver.
  2. Lenovo Edge 15 Wireless LAN Card Replacement: 步骤 2 中的图像 1,1
    • Gently lift the cover plate off the body of the laptop, ensuring that it does not pull on any components such as the USB ports.
  3. Lenovo Edge 15 Wireless LAN Card Replacement: 步骤 3 中的图像 1,1
    • Remove single 3mm screw holding down the end of the card using a Phillips #1 screwdriver.
  4. Lenovo Edge 15 Wireless LAN Card Replacement: 步骤 4 中的图像 1,2 Lenovo Edge 15 Wireless LAN Card Replacement: 步骤 4 中的图像 2,2
    • Use hands to disconnect card from slot and remove both cables.
    • When replacing connectors be sure to reconnect to proper terminal. Do this by orienting as is in the picture and attaching black cable to left side and white cable to right side.
结论
To reassemble your device, follow these instructions in reverse order. Make sure that connectors are in proper position as shown in step 3.
2等其他人完成本指南。
ryan sanders
于09/27/17注册
374 声望
创作了2篇指南
团队
Cal Poly, Team S8-G1, Banghart Fall 2017 Cal Poly, Team S8-G1, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S8G1
5 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 1,787
