跳转到主内容
Lenovo 100s Chromebook-11IBY Battery Replacement
你所需要的
  1. Lenovo 100s Chromebook-11IBY Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Battery Replacement: 步骤 3 中的图像 1,2 Lenovo 100s Chromebook-11IBY Battery Replacement: 步骤 3 中的图像 2,2
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Battery Replacement: 步骤 4 中的图像 1,2 Lenovo 100s Chromebook-11IBY Battery Replacement: 步骤 4 中的图像 2,2
    • Unlock the keyboard ZIF connector to release the keyboard flex cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Unlock the touchpad ZIF connector to release the touchpad flex cable.
    • Carefully pull both flex cables out of the ZIF connectors.
    • Remove the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Battery Replacement: 步骤 5 中的图像 1,1
    • Unplug the battery cable by pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo 100s Chromebook-11IBY Battery Replacement: 步骤 6 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove the three 6mm screws from the battery.
  7. Lenovo 100s Chromebook-11IBY Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the battery.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
2等其他人完成本指南。
Milton Perez
于03/09/17注册
630 声望
创作了5篇指南
团队
USF Tampa, Team S7-G2, Cagle Spring 2017 USF Tampa, Team S7-G2, Cagle Spring 2017 的会员
USFT-CAGLE-S17S7G2
1 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 2,349
