跳转到主内容
Laser Lens Cleaning
你所需要的
  1. Laser Lens Cleaning, Top Panel: 步骤 1 中的图像 1,2 Laser Lens Cleaning, Top Panel: 步骤 1 中的图像 2,2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Laser Lens Cleaning: 步骤 2 中的图像 1,2 Laser Lens Cleaning: 步骤 2 中的图像 2,2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Laser Lens Cleaning, Laser Lens Cleaning: 步骤 3 中的图像 1,2 Laser Lens Cleaning, Laser Lens Cleaning: 步骤 3 中的图像 2,2
    • Locate the lens on the disc drive.
    • Make sure that there is no dust on or near the player and area you are working on. Dust can get on the lens and scratch it while you are cleaning. It is very important that the lens is not damaged because the lens is used to read the discs.
    • Dip one end of a cotton swab in rubbing alcohol.
    • Lightly dab the swab on the lens. Be very gentle.
    • Let the lens dry before replacing the top plate of the DVD player.
结论
12等其他人完成本指南。
Nathan Klammer
于10/06/11注册
437 声望
创作了3篇指南
团队
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011 的会员
CPSU-MANESS-F11S21G20
4 名成员
创作了5篇指南
3条评论
This item was not appropriate, thank you for trying.
bigd734 - 回复
Works on Samsung's box(home theater), thank you!
CarlBraun - 回复
It worked on my cheap player. This unit is on 24/7. The dust in the house is heavy and smokers so the fix is cheap and I picked up a few things. Thanks
Seeker - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 47
过去 30 天: 293
总计 46,177
