跳转到主内容
LG Spectrum Motherboard Replacement
Aiman Sallam
Aiman Sallam3 其他贡献者
最后更新于 December 23, 2021
10分钟
困难
特色学生指南
If you are having issues with your motherboard, such as the blue screen of death, constant errors, or crashes you may need to replace the motherboard. This guide will take you through the necessary steps to replace the Motherboard.
你所需要的
工具
查看更多...
  1. LG Spectrum Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 LG Spectrum Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
  2. LG Spectrum Motherboard Replacement: 步骤 2 中的图像 1,1
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
  3. LG Spectrum Motherboard Replacement, Sim/SD Port: 步骤 3 中的图像 1,2 LG Spectrum Motherboard Replacement, Sim/SD Port: 步骤 3 中的图像 2,2
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnetic mat to keep the screws in one place.
  4. LG Spectrum Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
  5. LG Spectrum Motherboard Replacement: 步骤 5 中的图像 1,1
    • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
  6. LG Spectrum Motherboard Replacement: 步骤 6 中的图像 1,1
    • Hook the plastic opening tool underneath the plate and gently lift it up.
  7. LG Spectrum Motherboard Replacement: 步骤 7 中的图像 1,1
    • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
  8. LG Spectrum Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,2 LG Spectrum Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,2
    • Use the plastic opening tool to lift up the connector that holds the camera to the board.
  9. LG Spectrum Motherboard Replacement: 步骤 9 中的图像 1,1
    • Pull the camera gently out of its housing in the motherboard with your fingers.
  10. LG Spectrum Motherboard Replacement: 步骤 10 中的图像 1,2 LG Spectrum Motherboard Replacement: 步骤 10 中的图像 2,2
    • Using the plastic opening tool, gently pry up the audio port connector.
  11. LG Spectrum Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the audio port from the motherboard with either your hand or the plastic opening tool.
  12. LG Spectrum Motherboard Replacement: 步骤 12 中的图像 1,2 LG Spectrum Motherboard Replacement: 步骤 12 中的图像 2,2
    • Detach the two cable connector wires from the motherboard with the plastic opening tool.
    • Detach the remaining five connectors from the phone with the plastic opening tool.
  13. LG Spectrum Motherboard Replacement: 步骤 13 中的图像 1,2 LG Spectrum Motherboard Replacement: 步骤 13 中的图像 2,2
    • Hook the plastic opening tool underneath the motherboard and firmly lift it out of the phone casing.
结论
Aiman Sallam
于02/10/16注册
506 声望
创作了5篇指南
团队
USF Tampa, Team 1-4, Sullivan Spring 2016 USF Tampa, Team 1-4, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S1G4
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 635
