跳转到主内容
加入维修社区 - 创建账户
LG Refrigerator Freezer Ice Maker Replacement
你所需要的
    1. LG Refrigerator Freezer Ice Maker Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      询问修复机器人
      添加评论
    1. LG Refrigerator Freezer Ice Maker Replacement, Open the freezer door: 步骤 2 中的图像 1,2 LG Refrigerator Freezer Ice Maker Replacement, Open the freezer door: 步骤 2 中的图像 2,2
      • Pull open the freezer door fully.
      添加评论
    2. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: 步骤 3 中的图像 1,3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: 步骤 3 中的图像 2,3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer and bin: 步骤 3 中的图像 3,3
      • Lift and remove the upper pull-out drawer.
      • Lift and remove the main drawer bin.
      添加评论
    3. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: 步骤 4 中的图像 1,3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: 步骤 4 中的图像 2,3 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer rail covers: 步骤 4 中的图像 3,3
      • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
      • Lift the cover off of the rail and remove it.
      • Repeat this procedure for the left drawer rail cover.
      询问修复机器人
      添加评论
    4. LG Refrigerator Freezer Ice Maker Replacement, Reassembly notes: 步骤 5 中的图像 1,2 LG Refrigerator Freezer Ice Maker Replacement, Reassembly notes: 步骤 5 中的图像 2,2
      • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
      • Hold the drawer rail cover flush against the side of the drawer rail.
      • You should feel the locking tabs protruding.
      • Push the rail cover straight downward to install. It should click into place.
      询问修复机器人
      添加评论
    5. LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer: 步骤 6 中的图像 1,2 LG Refrigerator Freezer Ice Maker Replacement, Remove the drawer: 步骤 6 中的图像 2,2
      • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
      询问修复机器人
      添加评论
    6. LG Refrigerator Freezer Ice Maker Replacement: 步骤 7 中的图像 1,3 LG Refrigerator Freezer Ice Maker Replacement: 步骤 7 中的图像 2,3 LG Refrigerator Freezer Ice Maker Replacement: 步骤 7 中的图像 3,3
      • Lift the front of the drawer up.
      • Pull the drawer toward you to release the drawer from the drawer slides.
      • Remove the freezer drawer.
      询问修复机器人
      添加评论
    1. LG Refrigerator Freezer Ice Maker Replacement, Release the ice maker: 步骤 8 中的图像 1,1
      • Use a Phillips screwdriver to remove the screws securing the ice maker to the top of the freezer compartment.
      询问修复机器人
      添加评论
    2. LG Refrigerator Freezer Ice Maker Replacement: 步骤 9 中的图像 1,3 LG Refrigerator Freezer Ice Maker Replacement: 步骤 9 中的图像 2,3 LG Refrigerator Freezer Ice Maker Replacement: 步骤 9 中的图像 3,3
      • Insert a flat-blade screwdriver into the slot located on the right edge of the ice maker.
      • Pry outward with the screwdriver to release the locking tab securing the ice maker to the fridge.
      • When the tab releases, pull the right front corner of the ice maker down.
      询问修复机器人
      添加评论
    3. LG Refrigerator Freezer Ice Maker Replacement: 步骤 10 中的图像 1,1
      • Repeat the previous operation on the left side of the ice maker to release it.
      询问修复机器人
      添加评论
    4. LG Refrigerator Freezer Ice Maker Replacement: 步骤 11 中的图像 1,3 LG Refrigerator Freezer Ice Maker Replacement: 步骤 11 中的图像 2,3 LG Refrigerator Freezer Ice Maker Replacement: 步骤 11 中的图像 3,3
      • Grasp the front edge of the ice maker and pull it towards you.
      • Lower the ice maker.
      询问修复机器人
      添加评论
    5. LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: 步骤 12 中的图像 1,3 LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: 步骤 12 中的图像 2,3 LG Refrigerator Freezer Ice Maker Replacement, Disconnect and remove the ice maker: 步骤 12 中的图像 3,3
      • Squeeze the ice maker connector to release it and pull it straight out to disconnect it.
      • Remove the ice maker.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
取消:我没有完成这个指南。
4等其他人完成本指南。
Bill Gilbert
于06/30/22注册
40,174 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了56,259篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 138
过去 30 天: 567
总计 9,669
