跳转到主内容
加入维修社区 - 创建账户
LG Refrigerator Control Board Replacement
你所需要的
  1. LG Refrigerator Control Board Replacement, Unplug your refrigerator: 步骤 1 中的图像 1,1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
    询问修复机器人
    添加评论
  2. LG Refrigerator Control Board Replacement, Unfasten the control board cover: 步骤 2 中的图像 1,1
    • Use a Phillips screwdriver to remove the screws securing the control board cover.
    询问修复机器人
    添加评论
  3. LG Refrigerator Control Board Replacement, Remove the control board cover: 步骤 3 中的图像 1,3 LG Refrigerator Control Board Replacement, Remove the control board cover: 步骤 3 中的图像 2,3 LG Refrigerator Control Board Replacement, Remove the control board cover: 步骤 3 中的图像 3,3
    • Tilt the top edge of the cover toward you and lift it off.
    询问修复机器人
    添加评论
  4. LG Refrigerator Control Board Replacement, Disconnect the control board: 步骤 4 中的图像 1,3 LG Refrigerator Control Board Replacement, Disconnect the control board: 步骤 4 中的图像 2,3 LG Refrigerator Control Board Replacement, Disconnect the control board: 步骤 4 中的图像 3,3
    • Note the position of each of the connectors, before disconnecting them. A photo is very valuable for keeping track, and taking several as you progress may be helpful.
    • Squeeze and pull the connectors to disconnect them from the control board.
    • Make sure to fully reconnect each connector when reassembling.
    询问修复机器人
    添加评论
  5. LG Refrigerator Control Board Replacement, Release the control board: 步骤 5 中的图像 1,3 LG Refrigerator Control Board Replacement, Release the control board: 步骤 5 中的图像 2,3 LG Refrigerator Control Board Replacement, Release the control board: 步骤 5 中的图像 3,3
    • Use your thumb to pry up and release the top left retaining clip securing the control board.
    • With your other hand, pull the top left corner of the control board out to loosen it.
    询问修复机器人
    添加评论
  6. LG Refrigerator Control Board Replacement: 步骤 6 中的图像 1,3 LG Refrigerator Control Board Replacement: 步骤 6 中的图像 2,3 LG Refrigerator Control Board Replacement: 步骤 6 中的图像 3,3
    • Repeat this process for each tab down the left edge of the control board as well as the top and bottom edges.
    询问修复机器人
    添加评论
  7. LG Refrigerator Control Board Replacement, Remove the control board: 步骤 7 中的图像 1,1
    • Lift the control board out by its edges and remove it.
    询问修复机器人
    添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
取消:我没有完成这个指南。
4等其他人完成本指南。
Bill Gilbert
于06/30/22注册
40,137 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了30,155篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 48
过去 30 天: 231
总计 4,841
