跳转到主内容
加入维修社区 - 创建账户
LG G Watch Display Assembly Replacement
你所需要的
    1. LG G Watch Display Assembly Replacement, Wristband: 步骤 1 中的图像 1,1
      在这个步骤中使用的工具:
      • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
      • Be prepared to apply some pressure with your fingers to perform the following action.
      • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
      • Grasp the exposed shoulder with the tweezers to perform the next step.
      添加评论
    2. LG G Watch Display Assembly Replacement: 步骤 2 中的图像 1,2 LG G Watch Display Assembly Replacement: 步骤 2 中的图像 2,2
      • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
      • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
      • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
      • Repeat steps 1 and 2 for the other wristband.
      询问修复机器人
      添加评论
    1. LG G Watch Display Assembly Replacement, Rear Case: 步骤 3 中的图像 1,1
      • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
      询问修复机器人
      添加评论
    2. LG G Watch Display Assembly Replacement: 步骤 4 中的图像 1,2 LG G Watch Display Assembly Replacement: 步骤 4 中的图像 2,2
      • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
      • Gently pull the two halves apart.
      询问修复机器人
      添加评论
    1. LG G Watch Display Assembly Replacement, Gasket: 步骤 5 中的图像 1,1
      在这个步骤中使用的工具:
      • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
      询问修复机器人
      添加评论
    1. LG G Watch Display Assembly Replacement, Motherboard: 步骤 6 中的图像 1,2 LG G Watch Display Assembly Replacement, Motherboard: 步骤 6 中的图像 2,2
      • Use the spudger to gently lift up and disconnect the display connector.
      • Now use the spudger to disconnect the digitizer connector.
      询问修复机器人
      添加评论
    2. LG G Watch Display Assembly Replacement: 步骤 7 中的图像 1,2 LG G Watch Display Assembly Replacement: 步骤 7 中的图像 2,2
      • Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws.
      • Use the spudger to gently remove the motherboard.
      询问修复机器人
      添加评论
    1. LG G Watch Display Assembly Replacement, Removing the screen: 步骤 8 中的图像 1,1
      • Apply a small amount of pressure to the back of the LCD to create a gap for the opening pick.
      • Gently work the pick around the perimeter of the device to loosen up the adhesive.
      • An iOpener may be necessary to help loosen up the adhesive. Refer to our iOpener guide for info on how to use it.
      询问修复机器人
      添加评论
    2. LG G Watch Display Assembly Replacement: 步骤 9 中的图像 1,2 LG G Watch Display Assembly Replacement: 步骤 9 中的图像 2,2
      • After using the pick to loosen the adhesive, simply pull the display assembly up from the metal bezel.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
USF Tampa, Team 2-5, Blackwell Fall 2014 USF Tampa, Team 2-5, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S2G5
5 名成员
创作了21篇指南
4指南评论
Where can you purchase replacement parts?
Brian Winebarger - 回复 分享
Someone knows where to find a screen replacement?, i found at alibaba but i have to buy 1k ... :(
George Momo Seyssel - 回复 分享
I found a 00 screwdriver was better than 000 for removing the motherboard.
Peter Jeremy - 回复 分享
Be smart buy a used one for nuthin on eBay….
jeromedaues - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 51
总计 5,033
