跳转到主内容
加入维修社区 - 创建账户
LG G Pad 8.3 Battery Replacement
你所需要的
    1. LG G Pad 8.3 Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 LG G Pad 8.3 Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
      • With the tablet face down, pull the SD card slot cover out.
      • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
      询问修复机器人
      添加评论
    2. LG G Pad 8.3 Battery Replacement: 步骤 2 中的图像 1,3 LG G Pad 8.3 Battery Replacement: 步骤 2 中的图像 2,3 LG G Pad 8.3 Battery Replacement: 步骤 2 中的图像 3,3
      • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
      • Pry the screen away from the back panel.
      • Repeat this on each edge of the device.
      • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
      • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
      添加评论
    3. LG G Pad 8.3 Battery Replacement: 步骤 3 中的图像 1,2 LG G Pad 8.3 Battery Replacement: 步骤 3 中的图像 2,2
      • After using the plastic opening tools, pry the device open with your hands.
      • Remove the back panel from the screen.
      询问修复机器人
      添加评论
    1. LG G Pad 8.3 Battery Replacement, Speaker: 步骤 4 中的图像 1,2 LG G Pad 8.3 Battery Replacement, Speaker: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      Magnetic Project Mat
      $19.95
      • Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
      • These screws are very small so make sure to keep track of them. You can use iFixit's Pro Magnetic Project Mat to help.
      添加评论
    2. LG G Pad 8.3 Battery Replacement: 步骤 5 中的图像 1,1
      • Use your fingers to remove the speaker.
      添加评论
    1. LG G Pad 8.3 Battery Replacement, Battery: 步骤 6 中的图像 1,2 LG G Pad 8.3 Battery Replacement, Battery: 步骤 6 中的图像 2,2
      • Remove the 3mm Phillips #000 screws from the corners of the battery.
      询问修复机器人
      添加评论
    2. LG G Pad 8.3 Battery Replacement: 步骤 7 中的图像 1,3 LG G Pad 8.3 Battery Replacement: 步骤 7 中的图像 2,3 LG G Pad 8.3 Battery Replacement: 步骤 7 中的图像 3,3
      • Using a spudger or a plastic opening tool, disconnect the ribbon cable from the right side of the device.
      • The cable is attached with an adhesive.
      • These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
      询问修复机器人
      添加评论
    3. LG G Pad 8.3 Battery Replacement: 步骤 8 中的图像 1,2 LG G Pad 8.3 Battery Replacement: 步骤 8 中的图像 2,2
      • Using the Phillips #000 screwdriver, remove the two 3mm screws located at the bottom of the ribbon cable.
      • Remove the ribbon cable from the device.
      询问修复机器人
      添加评论
    4. LG G Pad 8.3 Battery Replacement: 步骤 9 中的图像 1,2 LG G Pad 8.3 Battery Replacement: 步骤 9 中的图像 2,2
      • Unhook the battery from the top of the device.
      添加评论
结论
取消:我没有完成这个指南。
18等其他人完成本指南。
团队
CSU Fullerton, Team 1-6, Bruce Fall 2015 CSU Fullerton, Team 1-6, Bruce Fall 2015 的会员
CSUF-BRUCE-F15S1G6
4 名成员
创作了14篇指南
9指南评论
Every teardown I can find on this tablet has that darn screw in the sd card slot, but mine does not!! Does ANYBODY have teardown for mine? I can send pics, it's Verizon Gpad 8.3 LTE, slot holds sd and sim but NO screw. Son spilled water on it so screen is all dark and haptic stays on, I'd like to attempt the rice trick if I can open it.
Wesley Krasko - 回复 分享
The other models have a sponge adhesive on the back of the battery.
Completely disregard the first screw.
supramaster2099 - 回复 分享
Wesley - Me too. I have no idea why Android released two different models with the same freaking model name. I thought they had more common sense than that. If anyone has the teardown for the new model, holler.
Slavelike Constructs - 回复 分享
Same here. No screw
jon - 回复 分享
sorry this teardown is not for the 8.3
krackeddude - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 80
总计 45,969
