跳转到主内容
加入维修社区 - 创建账户
LG Front Load Washing Machine Stator Replacement
你所需要的
  1. LG Front Load Washing Machine Stator Replacement, Safety Precautions: 步骤 1 中的图像 1,2 LG Front Load Washing Machine Stator Replacement, Safety Precautions: 步骤 1 中的图像 2,2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    添加评论
  2. LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: 步骤 2 中的图像 1,3 LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: 步骤 2 中的图像 2,3 LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: 步骤 2 中的图像 3,3
    • Remove the screw(s) securing the rear panel.
    添加评论
  3. LG Front Load Washing Machine Stator Replacement, Remove the rear panel: 步骤 3 中的图像 1,3 LG Front Load Washing Machine Stator Replacement, Remove the rear panel: 步骤 3 中的图像 2,3 LG Front Load Washing Machine Stator Replacement, Remove the rear panel: 步骤 3 中的图像 3,3
    • Unclip the rear panel from the chassis.
    询问修复机器人
    添加评论
  4. LG Front Load Washing Machine Stator Replacement: 步骤 4 中的图像 1,1
    • Remove the rear panel.
    询问修复机器人
    添加评论
  5. LG Front Load Washing Machine Stator Replacement, Unfasten the rotor: 步骤 5 中的图像 1,2 LG Front Load Washing Machine Stator Replacement, Unfasten the rotor: 步骤 5 中的图像 2,2
    • Use an impact driver to remove the 17 mm nut securing the rotor.
    • Alternatively, you can use a wrench and a hammer to loosen the nut.
    • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
    询问修复机器人
    添加评论
  6. LG Front Load Washing Machine Stator Replacement, Remove the rotor: 步骤 6 中的图像 1,2 LG Front Load Washing Machine Stator Replacement, Remove the rotor: 步骤 6 中的图像 2,2
    • The rotor is magnetically attracted to the stator.
    • Pull the rotor straight off the stator and drive shaft splines to remove it.
    • Wiggle the rotor as you pull to help disconnect it.
    • This may require significant force.
    • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
    添加评论
  7. LG Front Load Washing Machine Stator Replacement, Unfasten the motor harness: 步骤 7 中的图像 1,1
    • Remove the screw(s) securing the motor harness.
    询问修复机器人
    添加评论
  8. LG Front Load Washing Machine Stator Replacement, Unfasten the stator: 步骤 8 中的图像 1,2 LG Front Load Washing Machine Stator Replacement, Unfasten the stator: 步骤 8 中的图像 2,2
    • Hold the stator up as you unfasten the last few bolts, as it can fall over unexpectedly.
    • Remove the bolts securing the stator.
    • During reassembly, refasten the screws in a "star" pattern.
    询问修复机器人
    添加评论
  9. LG Front Load Washing Machine Stator Replacement, Reposition the stator: 步骤 9 中的图像 1,3 LG Front Load Washing Machine Stator Replacement, Reposition the stator: 步骤 9 中的图像 2,3 LG Front Load Washing Machine Stator Replacement, Reposition the stator: 步骤 9 中的图像 3,3
    • Don't pull the stator too far away from the device, as it's still connected by wires.
    • Pull the stator out of its slot on the drum, and flip it so its rear is facing upward.
    询问修复机器人
    添加评论
  10. LG Front Load Washing Machine Stator Replacement, Disconnect the stator: 步骤 10 中的图像 1,3 LG Front Load Washing Machine Stator Replacement, Disconnect the stator: 步骤 10 中的图像 2,3 LG Front Load Washing Machine Stator Replacement, Disconnect the stator: 步骤 10 中的图像 3,3
    • Disconnect the connectors attached to the stator.
    • Always grip cables by their connectors and not the wires themselves.
    询问修复机器人
    添加评论
  11. LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: 步骤 11 中的图像 1,3 LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: 步骤 11 中的图像 2,3 LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: 步骤 11 中的图像 3,3
    • Use your fingers to unclip the rotor position sensor from the stator.
    • Pull the sensor away from the stator to completely unclip it.
    • Remove the rotor position sensor.
    • You're left with the stator.
    询问修复机器人
    添加评论
结论
Repair didn’t go as planned? Ask our Answers community for help.
取消:我没有完成这个指南。
2等其他人完成本指南。
Bill Gilbert
于06/30/22注册
40,137 声望
创作了261篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了28,236篇指南
5指南评论
I don’t have comment just question. Does this particular model have a drive belt? Mine is not spinning properly
Leilani Seymour - 回复 分享
No it does not. It is a direct drive machine, meaning that the motor drives the wash basket directly. Take a look at this link for some help.
Bill Gilbert - 回复 分享
I undertook this repair with the wd14071sd6 model to replace the hall sensor as I was getting the LE error code. I have noted on step 2 that the entire back panel had to be removed to access the rotor. This is very very awkward, as multiple electrics are also connected to the panel via plastic clips.
Despite this, the repair can be achieved without any major electric disconnection work just a matter or having enough space to carefully remove things.
Phill Birtles - 回复 分享
Te alguns estator que não usam o sensor Hall a minha lava seca LG wd17vts6 está máquina tem sensor Hall no estator
Dúvidas, obrigado
ROMUALDO GUIMARAES - 回复 分享
A máquina LG wd17vrs6 (modelo) usa sensor Hall no seu estator
Dúvida poderia me informar
Obrigado
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 90
总计 2,431
