简介
If you have a bad motherboard or are using it for parts this guide with show you how to retrieve the motherboard from your LG Fortune phone.
你所需要的
Use the slit on the bottom right side of the phone to open the back cover of your phone.
Slowly pry the back cover off the phone starting from the bottom up to the top.
Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
Remove the back panelling from the device with your fingers or a spudger.
Work slowly side to side to release this back casing and expose the motherboard.
Place a spudger or an opening tool under the edge of the video card press connector and pry straight up to disconnect it from the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
