跳转到主内容
加入维修社区 - 创建账户
Kurio 7 Speaker Replacement
你所需要的
    1. Kurio 7 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,3 Kurio 7 Speaker Replacement, Back Panel: 步骤 1 中的图像 2,3 Kurio 7 Speaker Replacement, Back Panel: 步骤 1 中的图像 3,3
      • Begin by removing the rubber cover from the Kurio 7.
      询问修复机器人
      添加评论
    2. Kurio 7 Speaker Replacement: 步骤 2 中的图像 1,2 Kurio 7 Speaker Replacement: 步骤 2 中的图像 2,2
      • Remove the four 30 mm Phillips #00 screws from the outer case.
      询问修复机器人
      添加评论
    3. Kurio 7 Speaker Replacement: 步骤 3 中的图像 1,2 Kurio 7 Speaker Replacement: 步骤 3 中的图像 2,2
      • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
      • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
      • Be careful not to break off the tabs that hold the front cover and the back cover together.
      询问修复机器人
      添加评论
    4. Kurio 7 Speaker Replacement: 步骤 4 中的图像 1,2 Kurio 7 Speaker Replacement: 步骤 4 中的图像 2,2
      • Once all of the tabs are removed, the back cover should come off easily.
      • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
      询问修复机器人
      添加评论
    1. Kurio 7 Speaker Replacement, Kurio 7 Motherboard Removal Guide: 步骤 5 中的图像 1,2 Kurio 7 Speaker Replacement, Kurio 7 Motherboard Removal Guide: 步骤 5 中的图像 2,2
      • Use a plastic credit card, or other thin object, to separate the battery from the screen.
      • Be sure to work the card carefully and slowly around in order to not damage, break, or deform the battery.
      • Carefully set the battery aside.
      询问修复机器人
      添加评论
    2. Kurio 7 Speaker Replacement: 步骤 6 中的图像 1,2 Kurio 7 Speaker Replacement: 步骤 6 中的图像 2,2
      • Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place.
      询问修复机器人
      添加评论
    3. Kurio 7 Speaker Replacement: 步骤 7 中的图像 1,3 Kurio 7 Speaker Replacement: 步骤 7 中的图像 2,3 Kurio 7 Speaker Replacement: 步骤 7 中的图像 3,3
      • Place the plastic opening tool on the base of the black ribbon clip and pull up, like a lever, to release the mount. This should release the clip holding the ribbon to the mount.
      • Pull the ribbon out of the mount.
      询问修复机器人
      添加评论
    4. Kurio 7 Speaker Replacement: 步骤 8 中的图像 1,1
      • There should be masking tape on the yellow ribbon. Pull the tape off of the motherboard and wrap it around the yellow ribbon.
      • Do not pull the tape completely off the motherboard, as it is used to protect components on the ribbon.
      • To remove the ribbon from the mount, follow the same steps in Step 3.
      询问修复机器人
      添加评论
    5. Kurio 7 Speaker Replacement: 步骤 9 中的图像 1,1
      • Pull back the ribbons and put the battery near the bottom of the Kurio.
      • The motherboard is now removed so that other components can be worked on.
      询问修复机器人
      添加评论
    1. Kurio 7 Speaker Replacement, Speaker: 步骤 10 中的图像 1,1
      在这个步骤中使用的工具:
      • Pull the wires off of the motherboard using the tweezers. The wires aren't soldered on well.
      • Before you do break the solder, check the wires connections. You may be able to just solder the wire if it is already broken off.
      询问修复机器人
      添加评论
    2. Kurio 7 Speaker Replacement: 步骤 11 中的图像 1,2 Kurio 7 Speaker Replacement: 步骤 11 中的图像 2,2
      • Remove any hot glue residue holding the speaker in place by peeling it off using tweezers.
      询问修复机器人
      添加评论
    3. Kurio 7 Speaker Replacement: 步骤 12 中的图像 1,3 Kurio 7 Speaker Replacement: 步骤 12 中的图像 2,3 Kurio 7 Speaker Replacement: 步骤 12 中的图像 3,3
      • Use the spudger to pry out the old speaker.
      • You have successfully removed the speaker!
      询问修复机器人
      添加评论
结论
Solder in the new speaker. Refer to the soldering guide if you're unsure on how to solder. To reassemble your device, follow these instructions in reverse order.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Alex Powaser
于04/14/14注册
331 声望
创作了2篇指南
团队
Cal Poly, Team 12-36, Maness Spring 2014 Cal Poly, Team 12-36, Maness Spring 2014 的会员
CPSU-MANESS-S14S12G36
4 名成员
创作了28篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 37
总计 2,401
