跳转到主内容
加入维修社区 - 创建账户
Kindle Fire HDX 7" Display Assembly Replacement
你所需要的
    1. Kindle Fire HDX 7" Display Assembly Replacement, Speaker Bezel: 步骤 1 中的图像 1,3 Kindle Fire HDX 7" Display Assembly Replacement, Speaker Bezel: 步骤 1 中的图像 2,3 Kindle Fire HDX 7" Display Assembly Replacement, Speaker Bezel: 步骤 1 中的图像 3,3
      • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
      • The adhesive is strong and may require an iOpener, or heat gun, to soften.
      询问修复机器人
      添加评论
    2. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 2 中的图像 1,1
      • Remove the speaker bezel.
      询问修复机器人
      添加评论
    1. Kindle Fire HDX 7" Display Assembly Replacement, Rear Panel: 步骤 3 中的图像 1,1
      • Remove the six pink 3mm T3 Torx screws from the back case.
      询问修复机器人
      添加评论
    2. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 4 中的图像 1,2 Kindle Fire HDX 7" Display Assembly Replacement: 步骤 4 中的图像 2,2
      • Wedge opening picks around the perimeter between the display and back case.
      • Work the opening picks around the perimeter until the two halves disengage from each other.
      • Don't completely separate as the display ribbon cable still connects the two.
      询问修复机器人
      添加评论
    3. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 5 中的图像 1,1
      • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
      添加评论
      • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
      询问修复机器人
      添加评论
    1. Kindle Fire HDX 7" Display Assembly Replacement, Battery: 步骤 7 中的图像 1,1
      • Pry up the battery connector with the flat end of a spudger.
      询问修复机器人
      添加评论
    2. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 8 中的图像 1,2 Kindle Fire HDX 7" Display Assembly Replacement: 步骤 8 中的图像 2,2
      • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
      • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
      • Do not wear contact lenses without eye protection.
      • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
      询问修复机器人
      添加评论
    3. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 9 中的图像 1,1
      • Apply a small amount of adhesive remover (approximately 1 ml) evenly along the elevated edge of the battery cell.
      • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
      询问修复机器人
      添加评论
    4. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 10 中的图像 1,2 Kindle Fire HDX 7" Display Assembly Replacement: 步骤 10 中的图像 2,2
      • Slide a few opening picks between the battery and the raised metal edge.
      • Pry upwards to lift the battery up.
      • Step 15 may need to be repeated a few times to weaken the glue.
      询问修复机器人
      添加评论
    5. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 11 中的图像 1,2 Kindle Fire HDX 7" Display Assembly Replacement: 步骤 11 中的图像 2,2
      • Apply a small amount of adhesive remover (approximately 1 ml) underneath the battery and wait 2-3 minutes for it to penetrate.
      • You may need to repeat this a few times.
      • Continue prying up the battery.
      询问修复机器人
      添加评论
    6. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 12 中的图像 1,1
      • Remove the battery from the mid-frame.
      添加评论
    1. Kindle Fire HDX 7" Display Assembly Replacement, Motherboard: 步骤 13 中的图像 1,2 Kindle Fire HDX 7" Display Assembly Replacement, Motherboard: 步骤 13 中的图像 2,2
      在这个步骤中使用的工具:
      • Grab the yellow tape with a pair of tweezers and pull upwards to disconnect the press-fit connector.
      添加评论
    2. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 14 中的图像 1,1
      • Use the flat end of a spudger to disconnect the front camera press-fit connector from the motherboard.
      询问修复机器人
      添加评论
    3. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 15 中的图像 1,1
      • Remove the nine 3mm T6 Torx screws from the motherboard.
      添加评论
    4. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 16 中的图像 1,3 Kindle Fire HDX 7" Display Assembly Replacement: 步骤 16 中的图像 2,3 Kindle Fire HDX 7" Display Assembly Replacement: 步骤 16 中的图像 3,3
      • Use a spudger to pry up and disconnect the antenna cable from the motherboard.
      • Pull the antenna cable up and off of the motherboard.
      • Don't remove completely as it's soldered to the frame.
      询问修复机器人
      添加评论
    5. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 17 中的图像 1,1
      • Use a spudger to disconnect the second antenna cable from the motherboard.
      询问修复机器人
      添加评论
    6. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 18 中的图像 1,2 Kindle Fire HDX 7" Display Assembly Replacement: 步骤 18 中的图像 2,2
      • Use the flat end of a spudger to pry up and disconnect the front camera press-fit connector from the motherboard.
      • Remove the front camera.
      询问修复机器人
      添加评论
    7. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 19 中的图像 1,2 Kindle Fire HDX 7" Display Assembly Replacement: 步骤 19 中的图像 2,2
      • Remove the motherboard from the tablet.
      询问修复机器人
      添加评论
    1. Kindle Fire HDX 7" Display Assembly Replacement, Display Assembly: 步骤 20 中的图像 1,1
      • Heating the edges of the tablet will help soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or prepare an iOpener and apply it to the edge of the tablet for about 90 seconds in order to soften up the adhesive underneath.
      询问修复机器人
      添加评论
    2. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 21 中的图像 1,2 Kindle Fire HDX 7" Display Assembly Replacement: 步骤 21 中的图像 2,2
      • Insert an opening pick between the glass display and the metal mid-frame.
      • Insert a second opening pick above the first.
      询问修复机器人
      添加评论
    3. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 22 中的图像 1,3 Kindle Fire HDX 7" Display Assembly Replacement: 步骤 22 中的图像 2,3 Kindle Fire HDX 7" Display Assembly Replacement: 步骤 22 中的图像 3,3
      • Roll the second opening pick all the way around the perimeter of the display.
      询问修复机器人
      添加评论
    4. Kindle Fire HDX 7" Display Assembly Replacement: 步骤 23 中的图像 1,2 Kindle Fire HDX 7" Display Assembly Replacement: 步骤 23 中的图像 2,2
      • Lift up on the glass display to remove it from the metal mid-frame.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Blake Klein
于01/29/17注册
75,121 声望
创作了50篇指南
10指南评论
I don’t have access to opening picks or adhesive remover, what can I use in place of these?
Sophie Larson - 回复 分享
Sophie, I regularly use playing cards, plastic lids from various disposable containers, guitar picks, and little metal objects that I get from parts of a clock or other small mechanical device. You’d be surprised how useful some of the little doodads can be as pick or pry tools. Apart from that: look for little tool kits that come with replacement parts. Many sellers include them as part of the deal. They aren’t nearly as good as the iFixIt tools, but they will do in a pinch until you can afford the better tools.
Christopher Little - 回复 分享
This guide seems to explain how to remove the display, but not how to replace it with a new one, even though the guide clearly states ‘replacement’. All anyone is left with is a ripped apart HDX? Do you have a guide on how to actually replace the screen and not just take out the old one?
dalebutt - 回复 分享
I understand where you are coming from. It’s daunting enough to take the thing apart with all the thin ribbon cables and tiny wires, not to mention the PCB and battery removal possibly going wrong. Let me tell you, it’s not too tough to do the replacement by following the instructions in reverse. All you need to do is remember that the fate of the world rests in your steady hand. Just kidding.
My advice: take it one step at a time, take a break if you get impatient or nervous… as long as you need. While you are working on reassembling the device, give it a try in a dry run (without adhesive or screws), then do it for real once (and only when) you are comfortable with the assembly.
Coming to this to do a little screen replacement on the kindle HDX 7” , I noticed your steps seem a bit out of order. Not a major issue as I just scrolled down but some of the steps are in the wrong order, battery, screen and motherboard removal. Which may send some down the wrong path :) Otherwise excellent manual, helped me muchly! Thank you !
Ben - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 40
总计 7,286
