跳转到主内容
加入维修社区 - 创建账户
JBL Tune 510BT Power Button Replacement
你所需要的
    1. JBL Tune 510BT Power Button Replacement, Faceplate: 步骤 1 中的图像 1,2 JBL Tune 510BT Power Button Replacement, Faceplate: 步骤 1 中的图像 2,2
      • Firmly grasp the earmuff and pull away from the center until the lip of the earmuff is disengaged.
      • Pull the earmuff towards the center of the headphones until it is free.
      询问修复机器人
      添加评论
    2. JBL Tune 510BT Power Button Replacement: 步骤 2 中的图像 1,2 JBL Tune 510BT Power Button Replacement: 步骤 2 中的图像 2,2
      • Remove the three 3 mm screws using a JIS #00 screwdriver.
      询问修复机器人
      添加评论
    3. JBL Tune 510BT Power Button Replacement: 步骤 3 中的图像 1,1
      • Carefully remove the faceplate by lifting it firmly.
      • Avoid rough movements, as there is a single thin wire connecting the faceplate to the internals.
      • If the repair is for the right-side driver, be mindful of the charging port, as the faceplate has a slot there for it. Lift the opposite end and back the port out.
      • To completely detach the faceplate, desolder the wires from the connections on the motherboard.
      询问修复机器人
      添加评论
    1. JBL Tune 510BT Power Button Replacement, Power Button: 步骤 4 中的图像 1,2 JBL Tune 510BT Power Button Replacement, Power Button: 步骤 4 中的图像 2,2
      • Remove the 1 mm screw using a JIS #00 screwdriver.
      • Using your finger or a Jimmy, gently pry the circuit board from the casing, being careful to not pull too hard to dislodge the connected wires.
      询问修复机器人
      添加评论
    2. JBL Tune 510BT Power Button Replacement: 步骤 5 中的图像 1,2 JBL Tune 510BT Power Button Replacement: 步骤 5 中的图像 2,2
      • Gently push the damaged power button from the outside towards the inner part of the headphone casing until it dislodges.
      • Replace it with the new button by connecting the tabs at the top and swinging the button into place.
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
Andy Rich
于01/30/24注册
334 声望
创作了2篇指南
团队
2指南评论
Ref. Power button ?
Marcel De Taey - 回复 分享
Part number to replace the powder button?? 510BT
Chris - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 78
过去 30 天: 353
总计 7,437
