跳转到主内容
加入维修社区 - 创建账户
JBL Flip 2 Bluetooth Antenna Replacement
你所需要的
  1. JBL Flip 2 Bluetooth Antenna  Replacement, JBL Flip 2 Outer Case Disassembly: 步骤 1 中的图像 1,2 JBL Flip 2 Bluetooth Antenna  Replacement, JBL Flip 2 Outer Case Disassembly: 步骤 1 中的图像 2,2
    • Begin by removing the rubber caps on both sides of the JBL Flip 2 by using the black spudger to get in between the creases.
    • Be very careful when removing the NFC rubber cap. There is a chip that is glued to the inside of the rubber cap. So, peel the rubber cap off slowly and remove the chip on the inside while peeling the rubber cap off.
    添加评论
  2. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 2 中的图像 1,2 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 2 中的图像 2,2
    • Remove the eight 7.0 mm Phillips #1 screws on both sides of the JBL Flip 2.
    询问修复机器人
    添加评论
  3. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 3 中的图像 1,3 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 3 中的图像 2,3 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 3 中的图像 3,3
    • The NFC chip is glued onto the side of the device. Use the black spudger to separate the mic from the surface.
    • Be careful not to sever the wire connecting the nfc chip to the inside of the device.
    • Gently slide the NFC chip into the device through the slot that the wire comes from.
    添加评论
  4. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 4 中的图像 1,2 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 4 中的图像 2,2
    • Peel the black rubber piece from one end to the other.
    询问修复机器人
    添加评论
  5. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 5 中的图像 1,3 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 5 中的图像 2,3 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 5 中的图像 3,3
    • Remove the two 7.0 mm Phillips #1 screws.
    • Carefully detach the silver plastic cover by pulling both ends off.
    • Pull both ends at the same time with the same amount of force to prevent the cover from breaking.
    • Separate the silver plastic piece by pulling it off from the middle.
    添加评论
  6. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 6 中的图像 1,3 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 6 中的图像 2,3 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 6 中的图像 3,3
    • Using a flat-head screwdriver or spudger, pry out the 8 metal nibs on the back side of the speaker.
    • Repeat the same process for the 4 remaining metal nibs (two on each end).
    询问修复机器人
    添加评论
  7. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 7 中的图像 1,2 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 7 中的图像 2,2
    • Expand the metal casing and carefully slide it off the speaker.
    添加评论
  8. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 8 中的图像 1,2 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 8 中的图像 2,2
    • Using the driver adapter, first insert the #4 socket into the driver; followed by the #1 Philip's head bit in order to reach the three 13.0 mm screws.
    询问修复机器人
    添加评论
  9. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 9 中的图像 1,3 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 9 中的图像 2,3 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 9 中的图像 3,3
    • Using the classic spudger, get underneath the black tape strips found on both side of the device.
    • After lifting a portion of the tape off of the device, gently peel the tape off of the device, making sure to keep it intact.
    • There is another piece of tape on the side of the device with the control buttons. Lift the tape with the classic spudger and then peel the rest of the tape off.
    添加评论
  10. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 10 中的图像 1,3 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 10 中的图像 2,3 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 10 中的图像 3,3
    • Wedge a spudger between the two halves where the tape was to pry the device open.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    询问修复机器人
    添加评论
  11. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 11 中的图像 1,2 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 11 中的图像 2,2
    • Use the black spudger to disconnect the speaker cord from it's socket.
    添加评论
  12. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 12 中的图像 1,2 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 12 中的图像 2,2
    • Use the black spudger to disconnect the auxiliary wire from its socket.
    添加评论
  13. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 13 中的图像 1,1
    • Carefully remove the cable connecting the control chip to the motherboard.
    添加评论
  14. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 14 中的图像 1,2 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 14 中的图像 2,2
    • Using the black spudger, carefully remove the cord connecting the battery to the motherboard.
    添加评论
  15. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 15 中的图像 1,1
    • Carefully remove the cable connecting the nfc chip to the motherboard.
    询问修复机器人
    添加评论
  16. JBL Flip 2 Bluetooth Antenna  Replacement, Bluetooth Antenna: 步骤 16 中的图像 1,1
    • Separate the antenna off the plastic wall of the speaker by wedging it with the a spudger.
    • Be careful not to yank it because the antenna is glued to the plastic wall.
    询问修复机器人
    添加评论
  17. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 17 中的图像 1,2 JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 17 中的图像 2,2
    • Remove the wire from the insert on the wall of the plastic speaker casing.
    • Separate the entire motherboard from the JBL Flip 2 speaker.
    询问修复机器人
    添加评论
  18. JBL Flip 2 Bluetooth Antenna  Replacement: 步骤 18 中的图像 1,1
    • Check out IFixit's official soldering guide for help with these special projects.
    • Using the soldering iron, solder the new wire on.
    • The soldering iron will be very hot.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
Jonathan Wear
于02/09/16注册
1,276 声望
创作了5篇指南
团队
USF Tampa, Team 11-2, Cheng Spring 2016 USF Tampa, Team 11-2, Cheng Spring 2016 的会员
USFT-CHENG-S16S11G2
4 名成员
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 57
总计 7,836
