此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
进行进一步的维修还是只需更换损坏的前部面板?这个指南会指导你打开你的JBL Charge 3的第一步。
你所需要的
通过执行相反顺序的步骤来重新组装你的设备。
6等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
2指南评论
where can i buy a new front cover for mine? mine has got cracked
Cammy Innes - 回复 分享
It seems there may be different versions of Charge 3 covers in existence, as when I opened mine (carefully with a slim screwdriver) I was presented with a single cross head screw on each end which was holding one of the ends of the cover in place. I could remove the top end at both ends, but had to unscrew these screws to get the other end off. It was easy, just deviates from this guide quite a bit!
Thomas Hall - 回复 分享
