跳转到主内容
加入维修社区 - 创建账户
Instax Mini 90 Photo Flash Capacitor Replacement
你所需要的
    1. Instax Mini 90 Photo Flash Capacitor Replacement, Battery: 步骤 1 中的图像 1,2 Instax Mini 90 Photo Flash Capacitor Replacement, Battery: 步骤 1 中的图像 2,2
      • The battery compartment can be found on the backside of the camera. Pinpoint this compartment and focus on the right edge of the compartment gate to find the opening latch.
      询问修复机器人
      添加评论
    2. Instax Mini 90 Photo Flash Capacitor Replacement: 步骤 2 中的图像 1,2 Instax Mini 90 Photo Flash Capacitor Replacement: 步骤 2 中的图像 2,2
      • Pinch the latch in towards the battery compartment gate. This will release the gate and allow it to open.
      • Completely open the gate and remove from camera. Take out the battery and replace the gate.
      询问修复机器人
      添加评论
    1. Instax Mini 90 Photo Flash Capacitor Replacement, Photo Flash Capacitor: 步骤 3 中的图像 1,2 Instax Mini 90 Photo Flash Capacitor Replacement, Photo Flash Capacitor: 步骤 3 中的图像 2,2
      • Face the front side of the camera towards you. To locate the left side turn the left side of the camera towards you.
      • Take out the four screws, sized 4.75 mm, with the Phillips #000 screwdriver.
      询问修复机器人
      添加评论
    2. Instax Mini 90 Photo Flash Capacitor Replacement: 步骤 4 中的图像 1,2 Instax Mini 90 Photo Flash Capacitor Replacement: 步骤 4 中的图像 2,2
      • Looking at the left side, flip the top of the camera towards you to locate the top side of the camera.
      • Take out the screw, sized 9.75 mm, located on the top side, with a Phillips #000 screwdriver.
      询问修复机器人
      添加评论
    3. Instax Mini 90 Photo Flash Capacitor Replacement: 步骤 5 中的图像 1,2 Instax Mini 90 Photo Flash Capacitor Replacement: 步骤 5 中的图像 2,2
      • Looking at the top of the camera, flip the camera 180 degrees to locate the bottom side of the camera.
      • Take out the screw, sized 3.75 mm, located on the bottom side, this time with a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    4. Instax Mini 90 Photo Flash Capacitor Replacement: 步骤 6 中的图像 1,3 Instax Mini 90 Photo Flash Capacitor Replacement: 步骤 6 中的图像 2,3 Instax Mini 90 Photo Flash Capacitor Replacement: 步骤 6 中的图像 3,3
      • Remove the anchors that hold the strap to the body of the camera. There is one on top, and one on the bottom.
      • Use the black spudger to pry off the silver casing on the top and the bottom of the camera.
      • Remove the metal piece from which the film is ejected located on the right side of the camera. There is a 4.75 mm screw under the metal piece. Use a Phillips #000 screw driver to remove it.
      询问修复机器人
      添加评论
    5. Instax Mini 90 Photo Flash Capacitor Replacement: 步骤 7 中的图像 1,3 Instax Mini 90 Photo Flash Capacitor Replacement: 步骤 7 中的图像 2,3 Instax Mini 90 Photo Flash Capacitor Replacement: 步骤 7 中的图像 3,3
      • Open up the camera by releasing the latches on the top of the camera. Pry open the top half of the camera to reveal the capacitor. Locate the capacitor on the top left of the camera.
      • Before handling the capacitor, be sure to discharge it. See the Device Safety wiki for more information.
      • Use the black spudger to pry out the capacitor.
      • Desolder the brown and white wires, taking note of which goes where.
      • Solder the brown and white wires onto the new capacitor.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
USF Tampa, Team S2-G1, Nance Spring 2017 USF Tampa, Team S2-G1, Nance Spring 2017 的会员
USFT-NANCE-S17S2G1
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 45
总计 3,711
