简介
This guide will show the steps to accessing the interior of the speaker to address problems with the main buttons not making contact with the motherboard.
你所需要的
Use the spudger to pry off the plastic grate covering the speakers, then gently pull it off with your fingers.
Insert the Spudger between the corners of base and the face of the speaker to open the device. The screw on the upper right corner may be difficult to take out. If you cannot take it out with a screwdriver, using force to pull the face of the speaker apart may break the plastic that surrounds the screw.
