跳转到主内容
加入维修社区 - 创建账户
Insignia NS-CLLT01 Button Replacement
你所需要的
    1. Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: 步骤 1 中的图像 1,2 Insignia NS-CLLT01 Button Replacement, Insignia NS-CLLT01 Top Casing Removal: 步骤 1 中的图像 2,2
      • Lift the four adhesive covers on each of the corners on the bottom of the clock using a plastic opening tool or your fingernail.
      询问修复机器人
      添加评论
    2. Insignia NS-CLLT01 Button Replacement: 步骤 2 中的图像 1,3 Insignia NS-CLLT01 Button Replacement: 步骤 2 中的图像 2,3 Insignia NS-CLLT01 Button Replacement: 步骤 2 中的图像 3,3
      • On the bottom of the clock, use your fingernail to push the battery cover to the right.
      • Lift the battery cover up and to the right to reveal the batteries.
      询问修复机器人
      添加评论
    3. Insignia NS-CLLT01 Button Replacement: 步骤 3 中的图像 1,1
      • Remove the two AA batteries by pressing the end opposite of the spring towards that spring and lifting up.
      • Once the batteries are removed, close the cover.
      询问修复机器人
      添加评论
    4. Insignia NS-CLLT01 Button Replacement: 步骤 4 中的图像 1,1
      • Use a long Phillips #2 screwdriver to unscrew all six 10mm Phillips screws inside the bottom of the clock.
      • Turn over the device to allow the screws to fall out, being careful to catch them so that you do not lose any.
      • The screws may not come out of the bottom of the clock. As long as you have unscrewed them, the clock can still be opened.
      询问修复机器人
      添加评论
    5. Insignia NS-CLLT01 Button Replacement: 步骤 5 中的图像 1,3 Insignia NS-CLLT01 Button Replacement: 步骤 5 中的图像 2,3 Insignia NS-CLLT01 Button Replacement: 步骤 5 中的图像 3,3
      • Turn the clock back over.
      • Lift the top off of the clock by gripping the back of the iPhone dock and pulling straight up.
      询问修复机器人
      添加评论
    1. Insignia NS-CLLT01 Button Replacement, Button: 步骤 6 中的图像 1,1
      • Using the Phillips #2 screwdriver, unscrew the seven 6mm Phillips screws on the circuit board that is attached to the top of the case.
      询问修复机器人
      添加评论
    2. Insignia NS-CLLT01 Button Replacement: 步骤 7 中的图像 1,1
      • Lift the circuit board from the device.
      询问修复机器人
      添加评论
    3. Insignia NS-CLLT01 Button Replacement: 步骤 8 中的图像 1,2 Insignia NS-CLLT01 Button Replacement: 步骤 8 中的图像 2,2
      在这个步骤中使用的工具:
      • Detach the circuit board from the rest of the clock by gripping the sides of the white ribbon cable connector on the left-hand side of the board and pulling it straight off. You may need to use tweezers to grip the connector.
      询问修复机器人
      添加评论
    4. Insignia NS-CLLT01 Button Replacement: 步骤 9 中的图像 1,3 Insignia NS-CLLT01 Button Replacement: 步骤 9 中的图像 2,3 Insignia NS-CLLT01 Button Replacement: 步骤 9 中的图像 3,3
      • Use this soldering guide to remove and replace any buttons that were not working.
      • The buttons will be labeled on the top of the circuit board, and you will be working with the corresponding connections on the back.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
团队
Baylor, Team 6-9, Williams Fall 2015 Baylor, Team 6-9, Williams Fall 2015 的会员
BU-WILLIAMS-F15S6G9
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 33
总计 672
