跳转到主内容
加入维修社区 - 创建账户
InFocus Screenplay 4805 Lamp Replacement
你所需要的
  1. InFocus Screenplay 4805 Lamp Replacement, Remove the lamp door: 步骤 1 中的图像 1,1
    • Front panel assembly removal is not required.
    • To remove the lamp door, use a metal or plastic pry tool and unclip the lamp door from the projector. Set this aside for reassembly.
    询问修复机器人
    添加评论
  2. InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: 步骤 2 中的图像 1,3 InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: 步骤 2 中的图像 2,3 InFocus Screenplay 4805 Lamp Replacement, Disconnect the lamp: 步骤 2 中的图像 3,3
    • Beyond this step, the lamp can be replaced as an assembly and the guide is complete. If you want to rebuild the lamp with a new bulb and reuse the old housing, refer to this guide: InFocus Screenplay 4805 Lamp Rebuild
    • If you are replacing the lamp as an assembly, follow this guide in reverse from this step.
    • Remove the two gold 1 cm screws and washers on the side of lens housing using the 4.0 flat-head bit
    • Pinch the white wire tab to gently detach the side that connects with the lens housing.
    询问修复机器人
    添加评论
  3. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: 步骤 3 中的图像 1,2 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: 步骤 3 中的图像 2,2
    • This step is only required when rebuilding the old lamp with a replacement bulb.
    • Slide the bulb housing out of the projector.
    • Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
    询问修复机器人
    添加评论
  4. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: 步骤 4 中的图像 1,2 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: 步骤 4 中的图像 2,2
    • Gently pull the top of the bulb housing off.
    • Lift up the middle of the bulb housing to remove it.
    • Be careful of loose parts, such as the metal housing and the glass focusing lens.
    询问修复机器人
    添加评论
  5. InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: 步骤 5 中的图像 1,3 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: 步骤 5 中的图像 2,3 InFocus Screenplay 4805 Lamp Replacement, **REBUILD ONLY** Housing disassembly: 步骤 5 中的图像 3,3
    • Unhook the spring from the bulb housing.
    • Gently remove the bulb.
    询问修复机器人
    添加评论
结论
To reassemble the device, follow these instructions in reverse order.
取消:我没有完成这个指南。
另外一个人完成了本指南。
3指南评论
To remove and later disassemble the lamp, you don’t need to remove whole cover. Just open the lamp bay door and follow the steps starting  from 6!
madyogi - 回复 分享
madyogi, exactly. You are absolutely right!
ilya.zhizhin - 回复 分享
I was able to fix an old projector I got for $40. Thank you so much for the tutorial.
Madelyn Tapia - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 20
总计 1,953
