跳转到主内容
加入维修社区 - 创建账户
InFocus Screenplay 4805 Lamp Rebuild
你所需要的
  1. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 步骤 1 中的图像 1,2 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 步骤 1 中的图像 2,2
    • This guide assumes tht you have removed the lamp unit from the projector. If you have not, refer to this guide first: InFocus Screenplay 4805 Lamp Replacement
    • Slide the bulb housing out of the projector.
    • Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
    询问修复机器人
    添加评论
  2. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 步骤 2 中的图像 1,2 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 步骤 2 中的图像 2,2
    • This step is only required when rebuilding the old lamp with a replacement bulb.
    • Gently pull the top of the bulb housing off.
    • Lift up the middle of the bulb housing to remove it.
    • Be careful of loose parts, such as the metal housing and the glass focusing lens.
    询问修复机器人
    添加评论
  3. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 步骤 3 中的图像 1,3 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 步骤 3 中的图像 2,3 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: 步骤 3 中的图像 3,3
    • Unhook the spring from the bulb housing.
    • Gently remove the bulb.
    询问修复机器人
    添加评论
结论
To reassemble the device, follow these instructions in reverse order.
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 154
