本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Flip the projector right-side up and turn it so that the back ports are facing you.
Remove the 7mm metallic hex screws using the flat-head screwdriver.
Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
即将完成!
结论
另外一个人完成了本指南。
