跳转到主内容
Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755
Robert Hladun
Robert Hladun3 其他贡献者
最后更新于 March 9, 2023
15 - 30 分钟
中等
If your Alphacool Eispumpe VPP755 V.1 or V.2 makes a grinding sound during operation, stops and starts randomly or doesn't seem to flow liquid, use this guide to replace the impeller thrust washers.
The thrust washers provide a low friction surface for the impeller to spin against during operation. Damaged or defective thrust washers can cause the pump to omit a loud grinding noise and negatively affect its performance.
Step 6 requires you to carefully remove the keeper washer and is the most difficult task for this guide as the keeper can break if removed too aggressively.
Before beginning, make sure the pump is disconnected from any power source.
你所需要的
工具
  1. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755, Impeller Thrust Washers: 步骤 1 中的图像 1,2 Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755, Impeller Thrust Washers: 步骤 1 中的图像 2,2
    • Remove the eight 3.5 cm M4 hex screws securing the pump to the shroud.
  2. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 2 中的图像 1,2 Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 2 中的图像 2,2
    • Remove the tension ring and separate the pump from the shroud.
  3. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 3 中的图像 1,3 Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 3 中的图像 2,3 Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 3 中的图像 3,3
    • Gently wiggle the 2.5 mm flat head screw driver in between the divide of the keeper washer.
    • Slowly raise one side of the keeper washer above the top of the ceramic shaft.
    • Place the flat head screw driver under the opposite side of the keeper washer and pop it off the shaft.
    • Bending the keeper washer too far can break it. Be gentle when performing this step.
  4. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 4 中的图像 1,3 Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 4 中的图像 2,3 Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 4 中的图像 3,3
    • Remove the white keeper washer and the black upper thrust washer.
    • Seperate the impeller from the pump body.
    • Expect resistance when separating the impeller as a magnet is holding it down.
  5. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 5 中的图像 1,1
    • Remove the black lower thrust washer to complete the disassembly.
  6. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 6 中的图像 1,1
    • Install the first new thrust washer to the bottom of the ceramic shaft.
  7. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 7 中的图像 1,1
    • Install the impeller back onto the ceramic shaft on top of the bottom thrust washer.
  8. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 8 中的图像 1,1
    • Install the new top thrust washer onto the ceramic shaft.
  9. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 9 中的图像 1,3 Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 9 中的图像 2,3 Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 9 中的图像 3,3
    • Place the keeper washer on the tip of the ceramic shaft.
    • Use the flat head screw driver and the hex wrench to push both sides of the keeper washer down until it reseats itself on the shaft.
  10. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 10 中的图像 1,2 Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 10 中的图像 2,2
    • Place the pump into the bottom of the shroud and reposition the tension ring.
  11. Impeller Thrust Washer Replacement for Alphacool Eispumpe VPP755: 步骤 11 中的图像 1,1
    • Screw in the eight 3.5 cm M4 hex screws to complete the reassembly.
终点
另外一个人完成了本指南。
Robert Hladun
于09/22/20注册
243 声望
撰写一个指南
团队
2指南评论
Size of the washer?
tuo-liu - 回复
Information : this tutorial is related to a specific water cooling pump (Alphacool Eispumpe) used in some custom desktop computers.
Brendan - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 25
总计 2,001
