跳转到主内容
加入维修社区 - 创建账户
IdeaPad L340-15API Battery Replacement
你所需要的
    1. IdeaPad L340-15API Battery Replacement, Optical Drive: 步骤 1 中的图像 1,2 IdeaPad L340-15API Battery Replacement, Optical Drive: 步骤 1 中的图像 2,2
      • Before beginning the repair, make sure that the device is fully powered off.
      • Turn the laptop over so the bottom cover is facing up.
      • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
      询问修复机器人
      添加评论
    2. IdeaPad L340-15API Battery Replacement: 步骤 2 中的图像 1,2 IdeaPad L340-15API Battery Replacement: 步骤 2 中的图像 2,2
      • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
      • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
      询问修复机器人
      添加评论
    3. IdeaPad L340-15API Battery Replacement: 步骤 3 中的图像 1,2 IdeaPad L340-15API Battery Replacement: 步骤 3 中的图像 2,2
      • Place your thumb at the seam between the optical drive and the device.
      • Gently pull the component straight out from the device, taking care not to pull at an angle.
      询问修复机器人
      添加评论
    1. IdeaPad L340-15API Battery Replacement, Battery: 步骤 4 中的图像 1,2 IdeaPad L340-15API Battery Replacement, Battery: 步骤 4 中的图像 2,2
      • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
      询问修复机器人
      添加评论
    2. IdeaPad L340-15API Battery Replacement: 步骤 5 中的图像 1,3 IdeaPad L340-15API Battery Replacement: 步骤 5 中的图像 2,3 IdeaPad L340-15API Battery Replacement: 步骤 5 中的图像 3,3
      • Insert a plastic opening pick in the back left corner and wedge the panel open.
      • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
      • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
      • Remove the bottom cover.
      询问修复机器人
      添加评论
    3. IdeaPad L340-15API Battery Replacement: 步骤 6 中的图像 1,2 IdeaPad L340-15API Battery Replacement: 步骤 6 中的图像 2,2
      • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
      • Use a container/magnet strip to store the screws while working.
      询问修复机器人
      添加评论
    4. IdeaPad L340-15API Battery Replacement: 步骤 7 中的图像 1,3 IdeaPad L340-15API Battery Replacement: 步骤 7 中的图像 2,3 IdeaPad L340-15API Battery Replacement: 步骤 7 中的图像 3,3
      • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
      • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
      询问修复机器人
      添加评论
    5. IdeaPad L340-15API Battery Replacement: 步骤 8 中的图像 1,1
      • Remove the battery from the laptop.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
取消:我没有完成这个指南。
Ian
于10/15/25注册
347 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-5, Bowman Fall 2025 UMass Dartmouth, Team 2-5, Bowman Fall 2025 的会员
UMASSD-BOWMAN-F25S2G5
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 59
总计 396
