跳转到主内容
Huawei P10 Plus Headphone Jack Replacement
你所需要的
  1. Huawei P10 Plus Headphone Jack Replacement, Display: 步骤 1 中的图像 1,3 Huawei P10 Plus Headphone Jack Replacement, Display: 步骤 1 中的图像 2,3 Huawei P10 Plus Headphone Jack Replacement, Display: 步骤 1 中的图像 3,3
    • Use an iOpener to loosen the adhesive beneath the display, focusing on the upper and lower part of the display.
    • Use an opening pick, or iFlex, to separate the adhesive on all sides of the display.
    • To avoid damage to the display, do not push the tool too deeply into the phone.
  2. Huawei P10 Plus Headphone Jack Replacement: 步骤 2 中的图像 1,3 Huawei P10 Plus Headphone Jack Replacement: 步骤 2 中的图像 2,3 Huawei P10 Plus Headphone Jack Replacement: 步骤 2 中的图像 3,3
    • There is a thin display cable between the screen and phone, be very careful not to rip it when opening the device.
    • Place a suction cup, or iSclack, on the upper portion of the phone and lift the display off the midframe.
    • Don't remove the display, the cable is trapped under a bracket screwed to the phone. You can flip the display to lay it down without straining the cable, or simply hold it in the next steps.
  3. Huawei P10 Plus Headphone Jack Replacement, Unfasten the screw: 步骤 3 中的图像 1,1
    • Remove the 3.3 mm-long Phillips screw securing the display flex connector bracket.
  4. Huawei P10 Plus Headphone Jack Replacement: 步骤 4 中的图像 1,3 Huawei P10 Plus Headphone Jack Replacement: 步骤 4 中的图像 2,3 Huawei P10 Plus Headphone Jack Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $5.99
    购买
    • Open the metal bracket that covers the display flex cable.
    • Use a spudger to disconnect the display flex cable.
    • Remove the display.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
  5. Huawei P10 Plus Headphone Jack Replacement, Midframe: 步骤 5 中的图像 1,2 Huawei P10 Plus Headphone Jack Replacement, Midframe: 步骤 5 中的图像 2,2
    • Remove the 13 Phillips #00 screws.
    • Remove the metal shield which holds down the display flex connector.
  6. Huawei P10 Plus Headphone Jack Replacement: 步骤 6 中的图像 1,3 Huawei P10 Plus Headphone Jack Replacement: 步骤 6 中的图像 2,3 Huawei P10 Plus Headphone Jack Replacement: 步骤 6 中的图像 3,3
    • Remove the SIM card tray.
    • Use the pointed end of a spudger to pry out the mid frame until you can get a good grip.
  7. Huawei P10 Plus Headphone Jack Replacement: 步骤 7 中的图像 1,3 Huawei P10 Plus Headphone Jack Replacement: 步骤 7 中的图像 2,3 Huawei P10 Plus Headphone Jack Replacement: 步骤 7 中的图像 3,3
    • Remove the mid frame.
    • Disconnect the battery flex cable with a spudger.
  8. Huawei P10 Plus Headphone Jack Replacement, Headphone Jack: 步骤 8 中的图像 1,3 Huawei P10 Plus Headphone Jack Replacement, Headphone Jack: 步骤 8 中的图像 2,3 Huawei P10 Plus Headphone Jack Replacement, Headphone Jack: 步骤 8 中的图像 3,3
    • Disconnect the headphone jack flex cable with a spudger.
    • Use an iOpener to loosen the adhesive beneath the headphone jack.
    • Remove the headphone jack.
    • If your new part doesn't include the rubber gasket, you need to transfer it from your old headphone jack to the new one.
结论
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
另外一个人完成了本指南。
Dominik Schnabelrauch
于11/23/16注册
210,056 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
141 名成员
创作了17,895篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 940
