跳转到主内容
Huawei Mate 8 Loudspeaker Replacement
Theo Mat
Theo Mat2 其他贡献者
最后更新于 September 17, 2018
45分钟
中等
Use this guide to replace the loudspeaker in your Huawei Mate 8.
你所需要的
工具
查看更多...
  1. Huawei Mate 8 Loudspeaker Replacement, Back Cover: 步骤 1 中的图像 1,2 Huawei Mate 8 Loudspeaker Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Switch off your phone and remove the SIM card tray.
  2. Huawei Mate 8 Loudspeaker Replacement: 步骤 2 中的图像 1,1
    • Remove the Torx T2 screws from the bottom of the phone
  3. Huawei Mate 8 Loudspeaker Replacement: 步骤 3 中的图像 1,2 Huawei Mate 8 Loudspeaker Replacement: 步骤 3 中的图像 2,2
    • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
  4. Huawei Mate 8 Loudspeaker Replacement: 步骤 4 中的图像 1,3 Huawei Mate 8 Loudspeaker Replacement: 步骤 4 中的图像 2,3 Huawei Mate 8 Loudspeaker Replacement: 步骤 4 中的图像 3,3
    • Use an opening pick to fully separate the clips, releasing the phone.
    • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
    • Open the phone like a book from the SIM tray side.
    • Use a spudger, to disconnect the fingerprint sensor cable.
  5. Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: 步骤 5 中的图像 1,3 Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: 步骤 5 中的图像 2,3 Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: 步骤 5 中的图像 3,3
    • Remove the liquid indicator sticker.
    • Remove the Phillips #00 screw that holds down the metal shield.
    • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
    • Use a spudger to remove the metal shield.
  6. Huawei Mate 8 Loudspeaker Replacement: 步骤 6 中的图像 1,3 Huawei Mate 8 Loudspeaker Replacement: 步骤 6 中的图像 2,3 Huawei Mate 8 Loudspeaker Replacement: 步骤 6 中的图像 3,3
    • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
  7. Huawei Mate 8 Loudspeaker Replacement: 步骤 7 中的图像 1,1
    • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
  8. Huawei Mate 8 Loudspeaker Replacement: 步骤 8 中的图像 1,2 Huawei Mate 8 Loudspeaker Replacement: 步骤 8 中的图像 2,2
    • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
    • Remove the bracket.
  9. Huawei Mate 8 Loudspeaker Replacement: 步骤 9 中的图像 1,1
    • Use a spudger to disconnect the interconnect cable.
    • Remove the interconnect cable.
  10. Huawei Mate 8 Loudspeaker Replacement, Charging Board: 步骤 10 中的图像 1,3 Huawei Mate 8 Loudspeaker Replacement, Charging Board: 步骤 10 中的图像 2,3 Huawei Mate 8 Loudspeaker Replacement, Charging Board: 步骤 10 中的图像 3,3
    • Remove the two Phillips #00 screws.
    • Use the flat end a spudger to disconnect the loudspeaker flex connector.
    • Use the pointy end of a spudger to pry out the daughterboard.
    • Remove the daughterboard.
  11. Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: 步骤 11 中的图像 1,3 Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: 步骤 11 中的图像 2,3 Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: 步骤 11 中的图像 3,3
    • Use the tip of a spudger on the left side of the loudspeaker to pry it out.
    • Remove the loudspeaker.
结论
4等其他人完成本指南。
Theo Mat
于11/12/17注册
12,897 声望
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 1,061
