Huawei Mate 8 Charging Board Replacement
简介
转到步骤 1Use this guide to replace the charging board in your Huawei Mate 8 smartphone.
Remove the liquid indicator sticker.
Remove the Phillips #00 screw that holds down the metal shield.
Use a spudger to remove the metal shield.
Remove the two Phillips #00 screws.
Use the flat end a spudger to disconnect the loudspeaker flex connector.
Use the pointy end of a spudger to pry out the daughterboard.
Remove the daughterboard.
3等其他人完成本指南。
3条评论
Step 5 Daughterboard interconnect cable
Is step above Really required? Any issues if skip straight to step 7
Hello LCW,
you can jump straight to Step 7 but you should definitely disconnect your battery when working on your phone. However you can achieve that by only removing the metal shield and keep the display and interconnect cable plugged in. It’s just a bit of a fumbling.
Hi. I replaced the battery, but Huawei Mate 8 still does not charge.
Is there a charging IC that I need to replace?
Is the charging IC on the charging board, or on the motherboard?
If it is on the motherboard, where is it, and is it possible to change?
