跳转到主内容
How to tighten the Razor A handlebar clamp
Jordyn
Jordyn3 其他贡献者
最后更新于 August 4, 2023
1 - 2 分钟
非常容易
需要更好的图片
If your steering column suddenly collapses into itself, this guide is for you. This guide will show you how to tighten the T-tube column to prevent that from happening.
  1. How to tighten the Razor A handlebar clamp, How to tighten the Razor A handlebar clamp: 步骤 1 中的图像 1,1
    • Locate the T-tube clamp. It is in the middle of the steering column.
  2. How to tighten the Razor A handlebar clamp: 步骤 2 中的图像 1,2 How to tighten the Razor A handlebar clamp: 步骤 2 中的图像 2,2
    • Open the clamp by pulling the lever away from the scooter.
  3. How to tighten the Razor A handlebar clamp: 步骤 3 中的图像 1,2 How to tighten the Razor A handlebar clamp: 步骤 3 中的图像 2,2
    • Locate the screw on the side of clamp.
    • Turn the screw on the side of the clamp by hand in a clockwise direction.
    • Attempt to close the clamp. If the lever is too tight to close, loosen the screw slightly and try again.
    • The T-tube should now be locked in place. If it continues to fall down, repeat the instructions in this guide.
终点
Jordyn
于10/09/12注册
565 声望
创作了5篇指南
团队
Cal Poly, Team 9-13, Amido Fall 2012 Cal Poly, Team 9-13, Amido Fall 2012 的会员
CPSU-AMIDO-F12S9G13
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 22
总计 3,934
