跳转到主内容
加入维修社区 - 创建账户
How to join two wires with solder
你所需要的
    1. How to join two wires with solder, How to join two wires with solder: 步骤 1 中的图像 1,1
      • Put one of the paired wires on one of the helping hand's clamp. Put the other pair of wires on the remaining clamp.
      • Make sure the wires' stripped ends are facing each other or are towards the center of the workplace. If not, orientate the wires accordingly.
      询问修复机器人
      添加评论
    2. How to join two wires with solder: 步骤 2 中的图像 1,2 How to join two wires with solder: 步骤 2 中的图像 2,2
      • Using both stripped wire ends, wrap and tie both of the ends together.
      询问修复机器人
      添加评论
    3. How to join two wires with solder: 步骤 3 中的图像 1,1
      • Solder the tied ends of the filament.
      • Ensure to solder the connection completely, not just one area.
      • Try not to put too much solder on the connection, as it will add more resistance.
      询问修复机器人
      添加评论
    4. How to join two wires with solder: 步骤 4 中的图像 1,1
      • Pull on the two wires firmly to ensure the solder does not separate.
      询问修复机器人
      添加评论
    5. How to join two wires with solder: 步骤 5 中的图像 1,2 How to join two wires with solder: 步骤 5 中的图像 2,2
      • To properly protect the soldered wire connection, use heat shrink.
      • Cut enough heat shrink to cover the soldered connection.
      • Slip the heat shrink onto the connection.
      • Using a heat generator, such as a heat gun or a hairdryer, heat the heat shrink around all of the angles until it securely covers the soldered connection.
      询问修复机器人
      添加评论
结论
This technique will allow wires to be extended both electrically and structurally without the need of longer wires.
取消:我没有完成这个指南。
8等其他人完成本指南。
Joeny Zhen
于02/24/15注册
427 声望
撰写一个指南
团队
Cal Poly, Team 23-1, Green Winter 2015 Cal Poly, Team 23-1, Green Winter 2015 的会员
CPSU-GREEN-W15S23G1
4 名成员
创作了5篇指南
1指南评论
Perhaps I might recommend sliding the H.S. tubing on before soldering the joint in case the wires are connected on the other end to something else.
Nathaniel Loeblein - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 52
总计 4,501
