跳转到主内容
How to Use a Desoldering Pump
你所需要的
  1. How to Use a Desoldering Pump, Prime the pump: 步骤 1 中的图像 1,2 How to Use a Desoldering Pump, Prime the pump: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Desoldering Pump
    $3.99
    • If this is your first time using a desoldering pump, try priming and activating the pump a few times before you use it for desoldering purposes.
    • Firmly grasp the desoldering pump with your hand.
    • Depress the plunger until it locks in place.
    • This primes the spring-loaded piston for suction.
  2. How to Use a Desoldering Pump, Activate the pump: 步骤 2 中的图像 1,2 How to Use a Desoldering Pump, Activate the pump: 步骤 2 中的图像 2,2
    • To activate the pump, press the black side button.
    • This releases the spring-loaded piston, which creates a burst of suction at the nozzle.
    • The piston release creates a substantial kickback. Brace your hand when you use the pump to keep the nozzle steady.
  3. How to Use a Desoldering Pump, Desolder a joint: 步骤 3 中的图像 1,3 How to Use a Desoldering Pump, Desolder a joint: 步骤 3 中的图像 2,3 How to Use a Desoldering Pump, Desolder a joint: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    FixHub | Power Series Smart Soldering Iron
    $79.95
    • Do not use the desoldering pump to desolder joints near small surface-mounted (SMT) components. The heat spillover and suction may dislodge the SMT components.
    • Prime the desoldering pump by depressing the plunger.
    • Heat the solder joint until the solder is liquified. To help with heat transfer, add some solder onto the soldering iron's tip.
    • Position the pump's nozzle as close to the molten solder as possible.
    • The nozzle is made of heat-resistant plastic, so don't worry if you occasionally brush the tip with it.
    • Press the side button to activate the pump.
    • Repeat the process until the joint is clean. You can also use solder wick to help soak up any remnant solder.
  4. How to Use a Desoldering Pump, Clean the desoldering pump: 步骤 4 中的图像 1,3 How to Use a Desoldering Pump, Clean the desoldering pump: 步骤 4 中的图像 2,3 How to Use a Desoldering Pump, Clean the desoldering pump: 步骤 4 中的图像 3,3
    • To clean the pump, prime and activate the pump a few times. This pushes a rod through the nozzle and ensures that solder doesn't block it.
    • On the rare occasion when the pump needs a more thorough cleaning, you can disassemble the pump to clean it out:
    • Grasp the nozzle by its knurled edge.
    • Twist the nozzle counter-clockwise to unscrew it. This may be difficult due to a tight-fitting O-ring.
    • Remove the nozzle and clean out the pump interior.
结论
For soldering instructions and tips, follow this guide.
82等其他人完成本指南。
Arthur Shi
于01/03/18注册
310,385 声望
创作了701篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,649篇指南
4指南评论
Good review, but I’ve found that these small solder suckers don’t do a very good job. The much larger “Soldapult” (https://www.edsyn.com/product/DS017.html) provides much more suction and can often completely clear a joint in one use.
shamino - 回复
How does the tip not melt.
Mia Cipollone - 回复
Apply higher temperature on your soldering iron, above 380°C.
Use bigger tip, bigger heating surface provides more effecitive heat transfer.
SchwarzeKatz -
If you are asking about why the tip of the solder sucker doesn't melt, it is made of a heat resitant material. Notice the word resistant.
Budda Belly - 回复
添加评论
浏览统计数据:
过去 24 小时: 59
过去 7 天: 531
过去 30 天: 2,115
总计 105,089
